is it possible to do a ecu swap between two 97-98 prelude and have it still run?
Old Jan 7, 2004 | 03:35 PM
98lude's Avatar
Default is it possible to do a ecu swap between two 97-98 prelude and have it still run?
I was just wondering if this is possible. or better yet, has anyone done it before. Of course, there will still be the problem of the immobiliser, but if I have the original key to both the ecu, can I just put the key around the ignition area, and start it?
thanx in advance.
Old Jan 7, 2004 | 06:02 PM
stinger's Avatar
Default Re: is it possible to do a ecu swap between two 97-98 prelude and have it still run? (98lude)
mine ran with a 98 ecu....still obd2
Old Jan 8, 2004 | 03:27 AM
Gerhard_001's Avatar
Yes you can. It plugs in with no modifying anything.
kapone51
Apr 5, 2012 10:27 AM
djnikko
Mar 16, 2006 12:58 PM
2WYLD4U
Apr 18, 2003 02:24 PM
