My parking lights won't turn off!!!!
Old Jan 7, 2004 | 02:38 PM
Redek4's Avatar
Default My parking lights won't turn off!!!!
Ok, here's the back ground info....the guy who had my 97 Accord S.E. (4door) tried to wire up the front bumper turn signal to stay on w/ the parking lights. To make a long story short it didn't work....I don't know how he tried to run them but in order to turn my parking lights off I have to take out the fuse under the hood. The driver side turn signal housing has a huge melt spot on it. I'm gonna replace the driver and pass headlight harness, but I think it's something else....I need help asap!!!!
Old Jan 7, 2004 | 02:43 PM
The_Todd's Avatar
Farts in the shower
Default Re: My parking lights won't turn off!!!! (Redek4)
Sounds like he wired it to a "hot" line.....or just doesn't know his electrics very well...I would just undo what he did and search for bumper mods....some guy on here did a diy using a civic socket, hope this helps
Old Jan 7, 2004 | 02:44 PM
.bagged's Avatar
wow...good one. replace everything that guy touched and start over. if its all wiring you shouldnt get his too bad in the pocket book..
Old Jan 7, 2004 | 02:48 PM
Redek4's Avatar
Default Re: My parking lights won't turn off!!!! (bagged93accord)
Ok, I completely took out the driverside headlight harness (yesterday) and it's still doing the same thing, except now you here indicater tone when I put the fuse back in. Do you think the switch is burned out?
Old Jan 7, 2004 | 03:02 PM
akord 97's Avatar
try putting everything back to stock. Get a dual filament socket and use that. wire it up to the signal then use the other wire to tap the parking light.
Old Jan 7, 2004 | 03:07 PM
The_Todd's Avatar
Farts in the shower
Default Re: (akord 97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akord 97 &raquo;</TD></TR><TR><TD CLASS="quote">try putting everything back to stock. Get a dual filament socket and use that. wire it up to the signal then use the other wire to tap the parking light. </TD></TR></TABLE>
And have your friend that wired it in the first place and broke it pay for this new socket. And if you like smack him too
Old Jan 7, 2004 | 03:11 PM
Redek4's Avatar
Default Re: (VRDrvr)
I'm trying to get everything back to stock, working order....the parking lights just stay on and won't turn off unless I pull out the fuse under the hood
Old Jan 7, 2004 | 03:14 PM
The_Todd's Avatar
Farts in the shower
Default Re: (Redek4)
Here is also a note.....turn your car off and also don't have the lights in the "on" position when working on them...you can damage some electrics and burn bulbs too......plus its safer too.
Old Jan 7, 2004 | 03:24 PM
Redek4's Avatar
I realize that....what I'm saying is whether the car is on or off the lights still stay on when the fuse is in.
Old Jan 7, 2004 | 03:27 PM
The_Todd's Avatar
Farts in the shower
And is your car back to stock?? Is your friend with you now? as him WTF he touched and as he points break his finger.
.bagged's Avatar
the melting could have gone back to the switch...
Old Jan 7, 2004 | 03:28 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged93accord &raquo;</TD></TR><TR><TD CLASS="quote">the melting could have gone back to the switch...</TD></TR></TABLE>
True...also check your relays.
Old Jan 7, 2004 | 03:29 PM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">And is your car back to stock?? Is your friend with you now? as him WTF he touched and as he points break his finger.</TD></TR></TABLE>
hahah exactly dont let StUnNa's touch your car...
Old Jan 7, 2004 | 03:31 PM
The_Todd's Avatar
Farts in the shower
Default Re: (bagged93accord)
hahah exactly dont let StUnNa's touch your car...</TD></TR></TABLE>
LMAO, I am the only one who touches my car...cuz if it breaks then I know who to blame. (besides the tools that put it on)
Old Jan 7, 2004 | 03:55 PM
The_Todd's Avatar
Farts in the shower
So if you could also provide pics of the wiring this sTuNnA did it might help out too
Old Jan 7, 2004 | 04:25 PM
Redek4's Avatar
Default Re: My parking lights won't turn off!!!! (VRDrvr)
Where are the relays located?
If I had a digital camera I'd download the pic, it's on my to-get list
Old Jan 7, 2004 | 04:36 PM
crafty's Avatar
I have my original sockets from when i did this mod....
let me know if you need them
you need to find out where the wire is going to from the bumper lights and disconnect it.....
Old Jan 7, 2004 | 04:40 PM
The_Todd's Avatar
Farts in the shower
Relays should be in engine bay or under steering column area.....not 100% sure. But I would put money on the wiring looks like the sTuNNA strikes again.
Jay Millstone
Sep 8, 2018 09:49 AM
movalsb951
Mar 4, 2009 03:25 PM
Bo-C-Fuss
Jan 3, 2005 05:08 PM
