your thoughts on h&r race springs.?
Old Jan 7, 2004 | 02:32 PM
vtec-izm's Avatar
Default your thoughts on h&r race springs.?
im ditching my cheap coil-overs for a set of h&r race springs and probably switch to tokico blues. what do you guys think? the springs or shocks any good?
Old Jan 7, 2004 | 03:19 PM
davidjaii's Avatar
i have the race springs.. best $ spent... but hold out on the tokico blues... save to get kyb agx or koni... the blues will die pretty quick
Old Jan 7, 2004 | 03:29 PM
Nexx's Avatar
Default Re: your thoughts on h&r race springs.? (vtec-izm)
Double on the specification of the tokico blue shocks because I'm pretty sure they weren't made to handle the spring rate of 460 lb/in (f) of the H&R racing springs. Also, make sure NOT to cut the bumpstops. I asked an H&R representative awhile back and they told me to not trim the bumpstops or else your ride quality would be truly the suxor. =P
Good luck!
Old Jan 7, 2004 | 05:45 PM
vtec-izm's Avatar
Default Re: your thoughts on h&r race springs.? (balch104)
kool thanx for your opinions im def. nearing towards the kyb's now. i figured i'd save a bit with the blues but now i'll throw in alittle extra for the agx's
Old Jan 7, 2004 | 05:52 PM
Nihilation's Avatar
I'm running the H&R Race springs with the Tokico Illuminas. Ride quality is firm, but comfortable. No bouncing at all. Setting 2 up front 3 in the rear(5-way adjustable).
Old Jan 7, 2004 | 06:09 PM
davidjaii's Avatar
yea... how well u want to fix up ur car depends on how much ur willing to spend.. dont be cheap... n for the spring drop .... 2in for the front... 1.75 for the back for h&r race springs... sport springs are 1.75 front / 1.5 back... if i remember
Old Jan 7, 2004 | 08:21 PM
Ninjaboi_on_X's Avatar
hey guys I don't know what type of springs I have on my car because I bought it off my friend who didn't know as well. It's all black and it's definitely neuspeed. The front use to tuck somewhat (RS sedan) until I put my camber kit on so now it has no wheel gap in the front and barely any wheelgap in the rear. Can someone guess what type it is? I'm guessing it's Neuspeed Sport? I don't know so any help would be nice. Thanks!
Old Jan 7, 2004 | 09:34 PM
Db1 Supreme's Avatar
Default Re: your thoughts on h&r race springs.? (Ninjaboi_on_X)
im guessing its neuspeed race if there is no wheel gap
Old Jan 7, 2004 | 10:35 PM
svtec's Avatar
L D E S
Default Re: (Nihilation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nihilation &raquo;</TD></TR><TR><TD CLASS="quote">I'm running the H&R Race springs with the Tokico Illuminas. Ride quality is firm, but comfortable. No bouncing at all. Setting 2 up front 3 in the rear(5-way adjustable).</TD></TR></TABLE>
same, and the quality is pretty good.
Old Jan 8, 2004 | 01:32 AM
TSAngry's Avatar
Default Re: (svtec)
i was also planning on getting h&r race springs. will koni yellows work with the h&r race springs?
Old Jan 8, 2004 | 06:37 AM
START's Avatar
I am running H&R Race Springs in my 94 GSR and that is the best looking drop I have ever seen. Right now, I have the stock struts, and you know the springs killed them so you know my car rideability sucks but I am going with the same struts I had on my first GSR, Tokico 5 way adjustable.
Old Jan 8, 2004 | 09:05 AM
Hairy Gorilla's Avatar
Default Re: your thoughts on h&r race springs.? (START)
I personally love the drop on my GSR with neuspeed race springs. They are like the exact same to my knowledge. Definately go for them....
Old Jan 8, 2004 | 10:22 AM
DA-MAX's Avatar
IMO H&R Race is simply amazing...the ride is very tight on my AGXs and the drop is comparable to the low drop on the coilovers(which sucked ***) I had on the car before...I never regret on switching to H&R low drop, tight ride...I was in heaven the day I got them on!
honda305
Suspension & Brakes
Feb 23, 2010 09:59 AM
PnoyJeff
Suspension & Brakes
Aug 7, 2005 02:26 PM
sherfield2002
10
Jan 18, 2004 05:52 PM
Rev-Olution
Sep 15, 2003 02:18 PM
