H22A4 distributor wiring... wires don't match diagram
I've got a 92 Prelude with a H22a4. Currently throwing ECU code 9 (CYP sensor) I'm trying to verify that the CYPP and CYPM are wired correctly to b11 and b12 on the ecu, however the distributor I have doesn't match any of the wiring diagrams. They all show 7 wires on the main plug... and I only have 4 wires.... Here's a pic:
And here's the box it came in.... So this is ODB2 right??
I need to know on the harness shown in the picture, which wire is CYPP and which is CYPM.
ODB1 P13. Which means for me CYPP = b11 and CYPM = b12. What i'm looking for is what wires on the dizzy harness in the pic those ecu pins need to be connected to.
i know i'm running the same thing. but the picture you have shows me the OBDII distributor. You need to run a OBDI distributor with the P13.
No way around that huh? I've got the CKP sensor wired using the one on the crank. I though the only difference between the ODB1 and 2 distributors was that ODB2 doesn't have the CKP sensor inside?
I found something similar to the ODB2 diagram you have below. It shows the 2 CYP wires as black and yellow. My problem is those colors are nowhere on my distributors harness, as shown in the pic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR981002 »</TD></TR><TR><TD CLASS="quote">No way around that huh? I've got the CKP sensor wired using the one on the crank. I though the only difference between the ODB1 and 2 distributors was that ODB2 doesn't have the CKP sensor inside?</TD></TR></TABLE>
That and TDC sensor. the TDC and CKP are in aline.
OBDI wire color
CKP
Blue/Green B15
Blue/Yellow B16
TDC
Orange/Blue B13
White/Blue B14
CYP
Orange B11
White B12
OBDII
CKP
Blue C2
White C12
TDC
Green C3
Red C13
OBDI wire color
CKP
Blue/Green B15
Blue/Yellow B16
TDC
Orange/Blue B13
White/Blue B14
CYP
Orange B11
White B12
OBDII
CKP
Blue C2
White C12
TDC
Green C3
Red C13
dellman177
May 12, 2005 07:39 PM
serious
Jan 6, 2003 06:12 AM
