sites for info on B20 swap
Helping my g-f's brother with a B20 swap. The B20 is going in a 94+ Integra...not sure if it's OBDI or II (forgot to ask). I've searched and found some good info on h-t regarding what's involved (ie. IM, wiring, etc). I'm wondering if anyone knows any websites on this particular swap. I'm looking for detailed instructions. I've done other swaps before, but I just wanna cover my bases.
its not hard at all... Use the LS intake manifold, flywheel and LS tranny...reuse the LS harness...Its basically a replacement LS with a bigger bore
Exactly. It IS an ls engine with a different bore. Same stroke, same head, just different bore and in your case the valve cover will look newer. It should be a direct swap, just like you were putting in a new b18b.
