FRONT A/C MOUNT
Old Jan 7, 2004 | 10:52 AM
JAPCIVIC R's Avatar
Default FRONT A/C MOUNT
Is it safe to drive around with out the front mount that holds the a/c compressor. How unsafe is that as far as bustin any other mounts or gettin tweak
Old Jan 7, 2004 | 11:08 AM
mmuller's Avatar
Mad Scientist
Default Re: FRONT A/C MOUNT (JAPCIVIC R)
dont shift hard.Thats one of the 3 torque mounts....if you drive it like that for long you gonna end up breaking the other ones
Old Jan 8, 2004 | 05:19 AM
JAPCIVIC R's Avatar
Default Re: FRONT A/C MOUNT (mmuller)
thanks for the info, buy any chance, correct me if im wrong but the mount i need is the on off a del sol dohc since my block is a b18a1
Old Jan 8, 2004 | 05:33 AM
B18C2_sedan's Avatar
be gentle and you will be fine
Old Jan 8, 2004 | 11:04 AM
crxlsvtec's Avatar
you could also get prothane mount inserts and then you dont to need the vibration mounts
Old Jan 11, 2004 | 07:38 PM
Whitfield Inc.'s Avatar
if you want to run factory civic air condition pump than yes - 95-97 del sol vtec ac mount - if you have removed ac and simple need the mount than the integra one that came with your swap will work ( if you got one )
Old Jan 19, 2004 | 10:20 PM
crxlsvtec's Avatar
Default Re: FRONT A/C MOUNT (RageDzine)
or you could get a p54 bracked from honda and run your stock ac comp on the b 16 motor
spock_rocker
10
Jul 30, 2005 05:17 PM
ludedood97
13
Jan 18, 2005 08:21 AM
spike
Jul 9, 2004 12:24 PM
yaya
Jan 9, 2004 08:58 AM
