PW0 Ecu on Sohc Vtec motor?
Old Jan 7, 2004 | 07:40 AM
Z6REX-SI's Avatar
Default PW0 Ecu on Sohc Vtec motor?
I have a Z6 motor in my 88 REX-si. I was just wondering if I could use the PW0 Ecu to run my vtec instead of using the RPM activate switch? If so would this make my car run stronger than the PM6 Ecu that I have now? Thanks.
Old Jan 7, 2004 | 07:46 AM
91civicDXdude's Avatar
you'll have a knock sensor code.
also the engine will run VERY rich, and set the rev limit too high, so if you misshift, 8200 will probably blow your engine, or atleast **** your bearings.
if you could hook up a knock sensor on your z6, then it would run fairly well, but still rich and too high of rev limit
Old Jan 7, 2004 | 07:58 AM
Z6REX-SI's Avatar
Would it be the same story on a PR3? I also have full fuel upgrades so i could just lean it out a little on the regulator.
Old Jan 7, 2004 | 08:25 AM
EFSiR's Avatar
Default Re: PW0 Ecu on Sohc Vtec motor? (Z6REX-SI)
I've done it with PR3 Auto ECU and it run very strong. Play with the fuel Pressure and timing and you'll be very happy. I still have the A pipe with 2 oxygen spaces for sale , PM me if you want it.
scooterbuilteh2
Oct 27, 2009 11:44 PM
bobbymoon
Jun 11, 2009 04:34 PM
be18see1
Aug 17, 2007 08:14 PM
dohdoh420
Aug 1, 2006 12:38 AM
Bugermass
Nov 17, 2002 01:39 AM
