Question about OEM JDM cat-back for ITR
Old Sep 27, 2001 | 08:18 AM
Mycroft Holmes's Avatar
New User
Default Question about OEM JDM cat-back for ITR
OK, the 98 Spec-R has the 2.5" collecter on the exhaust manifold. I'm guessing the stock cat is also 2.5" as is the rest of the exhaust, but I never knew for sure. Anyone here know?
Also, does the factory B-pipe have the "neck down" where it bolts to the cat like the ITR B-pipe here, as well as my Tanabe exhaust, or is it 2.5" all the way?
Old Sep 27, 2001 | 08:23 AM
DutchITR1689's Avatar
Default Re: Question about OEM JDM cat-back for ITR (Mycroft Holmes)
Looking at the fact that the JDM aftermarket B-pipes have this bottleneck I think the stock JDM B-pipe must have it also......
Old Sep 27, 2001 | 09:55 AM
Back in Black's Avatar
Rather OG
Forgive me, but where are you located? The collector on my USDM manifold was definitely NOT 2.5", nor was the exhaust diameter. As for your second question, the USDM ITR does have the bottleneck located at the cat-bpipe connection...
For a solution to those hindering bottlenecks, contact Dave (SMSP).
Old Sep 27, 2001 | 09:58 AM
FBP_1171's Avatar
Default Re: Question about OEM JDM cat-back for ITR (Darth VadeR)
I believe he's talking about the JDM having the 2-1/2" collector, not the USDM.
Yes, talk to Dave. He provided my bottleneck solution.
Jason's Avatar
not once did he say USDM, if you read the title, it says OEM JDM
Old Sep 27, 2001 | 09:59 AM
New User
I am in North America. I was referring to the JDM 98 Spec-R with the 4-1 exhaust manifold. I was wondering if the JDM B-pipe has the bottleneck like the USDM one, and also what the diameter of the system is there.
Just curious.
[Modified by Mycroft Holmes, 1:00 PM 9/27/2001]
Old Sep 27, 2001 | 10:18 AM
Rather OG
Just curious.
My mistake...sorry
Old Sep 27, 2001 | 11:54 AM
FBP_1171's Avatar
USDM is metric, but rounds out to about 2-1/4 after the bottleneck. I think $45 for the adapter and it cost me $35 to weld in. Works great, only you can't easily go back to stock if you should need or choose to. I'm not sure, but I'm betting the JDM b-pipe is 2-1/4 with a taper to keep the transition smooth, which is exactly what the SMSP adapter does at what will end up being less $$$ than trying to get a hold of a JDM b-pipe.
Old Sep 27, 2001 | 02:09 PM
Mike M's Avatar
Founding Member
Default Re: Question about OEM JDM cat-back for ITR (FBP_1171)
JDM is the same size, No bottleneck, the JDM ITR Cat goes from the 2.5" on one end down to 2.25 at the end connecting to the B pipe Also the JDM B pipe is 5" longer than ours (same length as a GSRs)
Old Sep 27, 2001 | 03:48 PM
New User
Thank you for the replies!
I never intended to try to locate a JDM B-pipe, but I was curious about the bottleneck because I figure if it's on the JDM b-pipe it's there for a reason and thus would not bother altering my Tanabe G-Power's B-pipe. Since it isn't I think I'll get the adapter for mine. I take it that the adapter is a weld-on part that eliminates the bottleneck, huh?
So how do I get ahold of SMSP?
[Modified by Mycroft Holmes, 6:50 PM 9/27/2001]
Old Sep 27, 2001 | 05:07 PM
Rather OG
Default Re: (Mycroft Holmes)
I don't believe that David has posted a phone number yet, but the e-mail he's currently using is smsproducts@novacoxmail.com
Hope that helps
Old Sep 27, 2001 | 05:26 PM
New User
Default Re: (Darth VadeR)
It does. Thanks!
SoCal ITR
Feb 5, 2007 09:25 PM
rodimus
Nov 14, 2006 10:30 PM
TSAngry
Sep 15, 2004 07:02 AM
Reza.dc
Jan 6, 2004 06:11 PM
Rdriven
Jun 30, 2002 11:45 PM
