ef rear disk which work?
Old Jan 6, 2004 | 10:58 PM
buckNasty's Avatar
Default ef rear disk which work?
sorry please help
which rear disk setups will bolt up to my 89 std hatch?
what mods would i have to do, do struts change?
will i have to get new coilovers?
any help would be appreciated
Old Jan 6, 2004 | 11:28 PM
phan's Avatar
Default Re: ef rear disk which work? (bucbaby)
borrowed from temp due to laziness:
to PROPERLY do this you need the following
trailing arms (will come with calipers and rotors) from a 90-93 teg or 90-91 Si crx
CRX Si (90-91) ebrake cables (the teg ones will work but are too long and will need to be modified)
90-93 teg prop valve (all rear disk prop valves have "4040" stamped on them)
**and an 89 integra M/C (direct bolt in) or 90-93 teg brake booster and M/C
for more details on how to actually do this swap go here
http://www.fourthgenhatch.com/index2.html
go to technical and then how to and then 93 rear disc, this site is the best one i have seen on how to do this conversion and i used its instructions when i did mine, it also looks like he recently installed the teg booster and M/C which i will be doing shortly as well
and you will still use your 89 std shocks/springs/coilovers as before.
Old Jan 7, 2004 | 07:41 AM
temp's Avatar
Default Re: ef rear disk which work? (phan)
EDIT: since he has a hatch he might need to use the teg cables and cross them because the CRX Si e-brake cables (i am hearing) are too short
Old Jan 7, 2004 | 08:36 AM
EL Vap133's Avatar
Default Re: ef rear disk which work? (temp)
Yup, Teg e-brake cables will work...
Old Jan 7, 2004 | 08:45 AM
buckNasty's Avatar
thank u gentlemen
skill178
28
Nov 3, 2011 09:33 PM
gutted-dx
Jul 28, 2004 09:55 AM
TurboMeTroy
Jul 6, 2004 01:09 PM
ironchef25
33
Mar 5, 2004 05:04 AM
Pissoff
Jul 20, 2002 04:01 PM
