BEAKS - SUBFRAME RE-ENFORCEMENT KIT (SRK)
After seeing enough threads where members are baffled as to 'where' to find this particular product, I made a type specific thread. NOW, a 'search' will produce a result.
SRK-EG/DC
After extensive testing, Beaks Products' subframe reinforcement kit (SRK) has proven effective in safeguarding the vehicle's subframe when used with an oversized anti-sway bar upgrade. Due to thin construction of the sheet metal, mounting hardware often shears through the subframe, causing severe damage. The SRK provides reinforcement from both the inside and outside of the subframe. Loads are distributed over a large area. This reduces the stress and effectively prevents sheet metal failure.
Applications
All ABS and non-ABS equipped models of the following:
'92-'95 Honda Civic
'93-'97 Honda Civic del Sol
‘94-’00 Acura Integra (except Type-R)
Caution: SRK may not be compatible with some aftermarket exhaust systems. Up to 2.5" of mounting space directly outward from subframe is required for the anti-sway bar brackets. Please email for details.
Parts Included;
6061-T6 Aluminum Support Plates
6061-T6 Aluminum Nut Plates
Zinc Plated Grade-5 Bushing Bracket Flange Bolts
Zinc Plated Bushing Bracket Flat Washers
Installation Instructions
Additional Parts Required;
(Must purchase separately from Acura for complete ITR rear anti-sway bar setup)
P/N 52300-ST7-Z01 Integra Type-R Rear Stabilizer Bar (Qty. 1)
P/N 52315-ST7-Z01 Anti-sway Bar Bushing (Qty. 2*)
P/N 52308-SS0-000 Bushing Bracket (Qty. 2*)
P/N 52316-ST7-Z00 Endlink Bushing (Qty. 2)
P/N 52312-ST7-Z00 Endlink Bushing Collar (Qty. 4)
Stock Civic EX or Integra (any model) Rear Stabilizer Endlink Assembly (Qty. 2)
Price: $65.00 USD
SRK-EK
Developed with the same theory as the proven SRK-EG, Beaks Products' SRK-EK (subframe reinforcement kit) minimizes the chance of subframe "tear-out" often experienced with oversized anti-sway bar upgrades. Due to the thin construction of the subframe and insufficient factory reinforcements, the subframe sheet metal shears under extreme twisting of the anti-sway bar. The results are severe damage and expensive repairs. The SRK-EK reinforces the subframe from both inside and outside, distributing forces over a greater area of contact. This reduces the shear stress and effectively prevents sheet metal failures.
Applications
All non-ABS equipped models of the following:
'96-'00 Honda Civic
'99-'00 Honda Civic Si
Compatible with most aftermarket lower tie-bars!!!
Caution: SRK may not be compatible with some aftermarket exhaust systems. Up to 3.0" of mounting space directly outward from subframe is required for the anti-sway bar brackets. Please email for details.
Parts Included
Metal Endlink Collars
Metal Endlink Washers
P/N 52320-S04-003 '99-'00 Honda Civic Si Rear Stabilizer Endlink Assy., RH (Qty. 1)
P/N 52321-S04-003 '99-'00 Honda Civic Si Rear Stabilizer Endlink Assy., LH (Qty. 1)
Price: $65.00 USD
http://www.beaksproducts.com
THIS IS NOT MEANT TO BE AN ADVERTISEMENT; MOREOVER IT IS INTENDED AS INFORMATIONAL ONLY!
SRK-EG/DC
Applications
'92-'95 Honda Civic
Parts Included;
Price: $65.00 USD
SRK-EK
Applications
'96-'00 Honda Civic
Parts Included
Price: $65.00 USD
You should also add that it's hardly a guarantee that you won't rip your sub-frame and the comptech kit is the best way to go if you are really worried about it.
Kangolbrand
Apr 6, 2006 10:01 PM
52300st7z01, 52308ss0000, bar, beaks, bracket, bushings, car, civic, instructions, kit, pn, reinforcement, srk, srkegdc, stabilizer, subframe, tear, wa
