Need help removing dash trim...
Hi Guys,
I have a 95 model accord...i want to remove the dash trim to insert EL Gauges but having trouble removing it. Can anyone help me out? i'm affraid i might break some of the clips/mounts that hold the trim where the air-conditioning vent is.
Thanks for your help.
i believe to get to the guages, there are two screws: one underneath the interior light dimmer control, and the other under the rear window defroster switch, then the two that you can see above the guage cluster.
I've actually removed those screws...i've pulled off the section where the gauges are but the part where teh a/c vents are in the middle is quite rigid and i'm affraid i might crack it. any suggestions?
thanks
thanks
its not too hard, i dont remember where all the screws are but i was able to remove one off an extra front clip with no trouble at all and with out any manuals or nething. you should be able to just look around and figure it out
Hondatuner88
Audio / Security / Video
Sep 1, 2006 02:57 PM
RustyDX
Dec 17, 2001 03:23 PM
