H22 or H23 tranny?
Old Jan 6, 2004 | 07:26 PM
abeaujuin's Avatar
Default H22 or H23 tranny?
Maybe this lost of power is really in my tranny? Could my transmission be messed up? Could this cause my lack of power in first and hessitation in first? It is getting harder and harder to get it into first. If so, which should I get a H22 tranny or a H23?
Old Jan 6, 2004 | 10:06 PM
Kidd_Stylez's Avatar
Default Re: H22 or H23 tranny? (abeaujuin)
what kind of problems are you having that makes you think its in your tranny?? Have you done the obvious like bleed the clutch. As far as which tranny to get, this topic has been covered numerous times and it all comes down to what you want out of your driving experience.
Old Jan 7, 2004 | 04:55 AM
v4lu3s's Avatar
RTFM
i suspect that the hesitation and lack of power is a separate issue from getting into gear.
Old Jan 8, 2004 | 07:01 AM
abeaujuin's Avatar
Default Re: (v4lu3s)
I have changed the TPS. The car feels more powerful, but I don't think that was the problem. When I put the car in gear and letoff the clutch slowly, the car starts to stumble or chatter as if the clutch is trying to grab, or something. Ijust had the clutch replaced with a clutch master stage II about 4 months ago. The directions said that the flywheel needed to be resurfaced, but was never done. Do you think this could of been my problem all along?
Old Jan 8, 2004 | 08:17 AM
ForceThis!'s Avatar
Default Re: (abeaujuin)
very possibly, when the flywheel is warped, even if only very slightly that can certainly cause chatter, worse when its cold.
Cjek4
Apr 8, 2007 05:17 PM
stubk20
Feb 3, 2004 07:15 PM
H22ek4
Jul 2, 2003 06:20 PM
bew
May 10, 2003 09:02 PM
