Need help with B17
Old Jan 6, 2004 | 05:14 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Need help with B17
Aiight, my 93 Si hatch has a B17 in it that is absoloubltly screwed up. The thing runs very Rich. It prolly can go through a full tank of gas in 1 night. Len and i were checking out the codes, but it is throwing at least 3 codes. I will try to get them asap but i just wanted some insight as to what some may think can be wrong. Also, the timing is prolly bad off. I have even tried different ecus as well. Runs alot better on a p28, which i have in there at the moment. On the b17 ecu it didnt want to even run or keep idle. I havent had time to check the whole thing out though. The headgasket has been replaced, but that doesnt rule out a problem in the head. Any words would be highly appreciated.
Old Jan 6, 2004 | 05:19 PM
Patch's Avatar
Default Re: Need help with B17 (-BEN-)
Might be a headgasket, maybe a stuck open injector. I could tell you more if I knew the codes, but its probably an o2 code and a code 45.
Anyway, post them up when you find out.
Old Jan 6, 2004 | 07:55 PM
Stunna BEN's Avatar
Default Re: Need help with B17 (Patch)
I am gonna try to see if the injector is stuck or clogged while i am here at work. Hopefully that will help out some. We had trouble making the cams seat and line up correctly, so i am thinking the head is also warped, but i cannot confirm this as of yet.
Thanx for the advise
SIvic bob.tec
Jan 20, 2011 10:19 PM
97AccordProject
Jun 5, 2006 04:24 AM
BlackEJ6
Jan 13, 2006 03:02 PM
turbotime
Jul 29, 2003 03:23 PM
RexB16
Apr 14, 2002 11:13 PM
