94 cx gas tank problem
ok, i had to remove the gas tank from my 94 cx because it had a huge gaping hole in it. My question is....if i goto a junkyard...what honda's have the same gas tank as mine or one that will bolt up directly.
I want a cx tank...but would an ex or dx tank also fit? Also, how much should i expect to pay for a used gas tank minus the fuel pump(i was quoted $100 for an ex tank)?
-Thanks in advance
-Thanks in advance
CX and VX has a 10 gallon tank.
DX and Si has a 11.9 gallon tank.
Courtesy of B18C5-EH2 from his thread - https://honda-tech.com/zerothread?id=150315 ...
EDIT: This is for the 92-95 Hatchback(EH2/EG6).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES »</TD></TR><TR><TD CLASS="quote">CX is 11.9
Trust me. I put more than 10 gallons of gas in my car on a regular basis.</TD></TR></TABLE>
10g is tank capacity, not icluding the capacity of the filler tube which could account for your extra fuel
I've put more than 10g in my '93 CX, too.
**** i have run out of gas completely and filled back up even with that gallon of gas i put in the car to get me to the gas station, when i fill up i only get about 8 galons in teh tank. so if i didnt have that gallon i put on their earlier it would be 9 gallons. i filled up today i was on e completly, pump stopped at 8.5 gallons. so i had about half a gallon left in there. io can never get over 9 in the tank ever even when its empty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrewerHatch »</TD></TR><TR><TD CLASS="quote">
I've put more than 10g in my '93 CX, too.</TD></TR></TABLE>
weird, because I have filled up almost 14gallons more than once, and I fill up about 12gallons on a regular basis. I'm not trying to argue with anyone here, so please don't take it that way. But if someone says they've swapped tanks, and the cx is smaller, then that's teh way it is.....I just don't understand how I can fill up 13.5gallons with a 10gallon tank.
and if anyone wants to say i'm lying, trust me, I have no reason to lie about filling up 13.xx gallons of gas.
Weird.. unless your going to a station thats ripping you off
My '93 VX even when below red can only take 9.8 gallons topped off so someone must of changed out your tank ??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing »</TD></TR><TR><TD CLASS="quote">Weird.. unless your going to a station thats ripping you off
My '93 VX even when below red can only take 9.8 gallons topped off so someone must of changed out your tank ??</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Plan B »</TD></TR><TR><TD CLASS="quote">I swear that my CX has a 8 gallon tank. Completely empty = never more than 8 gallons. It's always like 7.8 gallons.
I don't trust pumps for accuracy anyway.</TD></TR></TABLE>
Read my post above yours. Whenever I fill up right on E it's like 7-7.5 gallons.
daymkimchee
Dec 23, 2009 12:56 PM
silverEH2
13
Apr 3, 2003 12:24 PM
