ANYWAY TO V-TEC A ZC?
Old Jan 6, 2004 | 01:25 PM
pyro_freak8's Avatar
Default ANYWAY TO VTEC A ZC?
IS THERE ANYWAY TO DO LIKE A MINI-ME SWAP FOR A ZC? ARE THERE ANY VTEC HEADS THAT WILL FIT IT? JUST WONDERING...
THANKS
Modified by pyro_freak8 at 12:30 PM 1/7/2004
Old Jan 6, 2004 | 01:33 PM
USDM 4G VTEC's Avatar
Default Re: ANYWAY TO V-TEC A ZC? (pyro_freak8)
nope
unfortunetly
unless u go to rice shoip and buy a big *** vtec sticker and put it on the valve cover
other than that,.. NO
Old Jan 6, 2004 | 01:46 PM
2point2's Avatar
Default Re: ANYWAY TO V-TEC A ZC? (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">nope
unfortunetly
other than that,.. NO </TD></TR></TABLE>
WRONG..
the sticker doesn't have to be big .
Old Jan 6, 2004 | 01:54 PM
SuperJay's Avatar
Default Re: ANYWAY TO V-TEC A ZC? (2point2)
sure their is! Pull out the enitire motor and replace with a VTEC'd motor! SOOOO SIMPO!!! Cap lox is your friend.
Old Jan 6, 2004 | 04:09 PM
Home Skillet's Avatar
Some guys on here can be so mean to new guys. Don't listen to these fools, just add VTEC fluid and you'll be fine.
Old Jan 6, 2004 | 04:10 PM
8Grand's Avatar
Old Jan 6, 2004 | 04:14 PM
bloopie's Avatar
Default Re: (8Grand)
If you have a SOHC ZC you can put a VTEC head on it.... or do they already come VTEC in the SOHC form?
Old Jan 6, 2004 | 04:21 PM
Timmah!!'s Avatar
Default Re: (razorku)
A set of cam regrids will do you well.
Thats all
you dont need VTEC, V-TEC, VEETECH, VVTAELC or anything else.
Old Jan 6, 2004 | 04:34 PM
Hybrid Invasion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyro_freak8 &raquo;</TD></TR><TR><TD CLASS="quote">IS THERE ANYWAY TO DO LIKE A MINI-ME SWAP FOR A ZC? ARE THERE ANY V-TEC HEADS THAT WILL FIT IT? JUST WONDERING...
THANKS</TD></TR></TABLE>you're kidding, right?
Old Jan 6, 2004 | 04:36 PM
slowman's Avatar
I took way too long
Default Re: ANYWAY TO V-TEC A ZC? (Hybrid Invasion)
Ok guys cut the BS.
A B16 head bolts right up to your ZC engine. No probs, you just slap her on! Bam there's VTEC!
Theres a write up somewhere, good luck!
Old Jan 6, 2004 | 04:42 PM
VtecKiDD's Avatar
Default Re: ANYWAY TO V-TEC A ZC? (slowman)
nah you guys got it all wrong. there WAS ACTUALY A ZC made in japan, the ZC-X that was a vtec motor. it came with pushrods, it was quad over head cam an it had 220hp. ultra rare JDM y0! you might have one man, , easiest way to tell is to drain all the oil out of your motor, an crank it up, if you start to hear a loud knocking noise , then you got one, consider yourself lucky.
all BS aside, NO IT WONT WORK. only way to get a vtec zc is to toss that zc aside an get a vtec motor, period
Old Jan 6, 2004 | 05:25 PM
rags2riches's Avatar
you can put the d16z6/d16y8 head on a sohc zc....
Old Jan 6, 2004 | 05:53 PM
VtecKiDD's Avatar
Default Re: (rags2riches)
well, i meant the DOHC ZC
Old Jan 6, 2004 | 06:13 PM
FULL-RACE EP3's Avatar
Default Re: (VtecKiDD)
mannn you guys are rough here on the ole' EF board....
Old Jan 6, 2004 | 07:06 PM
I dont see any reference of dohc here.....anyways, ive seen dohc zc heads on sohc blocks, so maybe its possible, but not worth the work in the end.
Old Jan 6, 2004 | 07:14 PM
speed_racer012's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8Grand &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> I didnt see anybody spell it vtech on this thread. I saw V-Tec
so shutup
Old Jan 6, 2004 | 08:36 PM
1point5CRX's Avatar
Default Re: (speed_racer012)
just get the vvti head of a celica,should pull 13's all day j/k
Old Jan 7, 2004 | 04:48 AM
kranked91dx's Avatar
Well about this tread, I don't know what to think, you guy's are not very kind in anyway... This poor noob's only want to ask a question, at least he know that we can change a head on an engine.
First: there is no vtec fluid, you can't crank up your engine with no oil, you cant have any rare as **** quad cam vtec engine and I really don't think you can slap a b16 head on a ZC.
now your only way to have a ZC vtec, it YES, do a mini swap on it and put a VTEC head on your <U>SOHC</U> ZC engine, that will work, for the DOHC, I don't know what ca be done.
see ya
Kranked
Old Jan 7, 2004 | 05:20 AM
therealciviczc's Avatar
WTF happened in this thread? It wasn't like this was a really stupid question or anything? So they guy doesn't know what heads fit on what motors. One person makes a legit but also humorous response, and suddenly everyone has to prove they can be funny too?
This place is going down hill.
Old Jan 7, 2004 | 06:06 AM
ThatRicerDaniel's Avatar
Default Re: (therealciviczc)
so hows the weather?
Old Jan 7, 2004 | 06:12 AM
Escabar's Avatar
you jackasses
Old Jan 7, 2004 | 06:26 AM
Default Re: (NitrousDreamz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NitrousDreamz &raquo;</TD></TR><TR><TD CLASS="quote">so hows the weather?</TD></TR></TABLE>
Real damn cool... Hence my hatred of everything.
Old Jan 7, 2004 | 07:25 AM
well, thanks for the flaming guys.....
i might be a newb to this forum but i'm not to hondas... i liked the sticker idea, but too ricey, hmmm i really liked the drain all the fluids out, maybe i'll do that and start it up j/k
well, anyway, it was just a question, never heard of it being done, what i've seen so far with hondas is that basically anything is possible with time and the right parts
oh, and by the way it's DOHC
Old Jan 7, 2004 | 08:36 AM
I8ayellowcrayon's Avatar
Azroth had a good start, but it will take a little more for a ZC to run with a B16. Higher lifting cams, advance timing a little bit (4* maybe) and get your ECU chipped to run a more aggressive fuel map. Then you'll have VTEC all the time!
There is no DOHC VTEC head that will bolt onto a DOHC ZC block. The DOHC ZC head will not bolt onto a SOHC block. I think there are a couple complications with putting a ZC head on a D16A1 block.
EDIT: I have heard of a D16A1 head being bolted onto an EW-1 block (1g carbureted CRX, maybe Civic too), but I've heard there are also some complications on that swap too.
Old Jan 7, 2004 | 10:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by therealciviczc &raquo;</TD></TR><TR><TD CLASS="quote">This place is going down hill. </TD></TR></TABLE>Correction....Honda-Tech jumped the shark long ago.
