The joys of grinds: B16 Gearbox alternatives?
Old Jan 6, 2004 | 06:25 AM
Driven's Avatar
Default The joys of grinds: B16 Gearbox alternatives?
Well, my S1 is on it's way out. The synchros are gone between 2nd gear and 3rd gear, as well as 3rd gear to 4th.
trying to rebuild it will cost me nearly... well, it'll cost a lot.
so, my other option is, find another gearbox. What are my options?
GSR gearbox?
ITR?
LS?
another JDM gearbox that i can't get rebuild kits stateside, unless it's for $400 from some guy on H-T?
I don't mind making a hydro to cable conversion kit...plus, i'd like to get a LSD some day...
any ideas?
Old Jan 6, 2004 | 06:50 AM
EP3_05's Avatar
Default Re: The joys of grinds: B16 Gearbox alternatives? (Driven)
I would make your own homemade cable-hydro conversion kit and get an ITR transmission. Since it already comes with a factory LSD this route should be cheaper in the long run than getting another jdm cable transmission and installing an aftermarket LSD.
Old Jan 6, 2004 | 07:19 AM
temp's Avatar
you have 3 options
HASport conversion kit w/ hydro tranny
win-sports gearing kit
adelia gearing kit
they will all run you roughly the same price
Old Jan 6, 2004 | 08:45 AM
Eggman's Avatar
i thought all B16A 90-91 (S1/Y1/J1) trannies use D-series synchros. ask 'Mista Bone' for down low on that. if i'm right, than a rebuild is one option.
else, get another used B16A/B17A cable tranny (that will probably need a rebuild soon too).
else, get the hydro mount conversion.
else, get a 92-93 B-series tranny casing (VTEC or non-VTEC) and swap all the internals of any 94+ hyrdo VTEC B-series in it. 94+ internals are a dime a dozen.
Old Jan 6, 2004 | 09:37 AM
EL Vap133's Avatar
Do what I did, I got tired of the cable tranny and decided to buy an ITR trans. B16a SI Hydro trans were going for $700 with no LSD so I said "why not get an ITR trans with LSD for about $300 more?" So then I got a killer deal on the Hasport Hydro conversion kit which includes all 3 mounts and the mechanism and I am now in the process of installing it pretty soon.
Old Jan 6, 2004 | 09:44 AM
temp's Avatar
Default Re: The joys of grinds: B16 Gearbox alternatives? (EL Vap133)
i can't wait to see pix EL......i want to run an ITR trans w/ the 4.785 FD but i need to be sure the conversion kit will work
Old Jan 6, 2004 | 08:08 PM
J Money's Avatar
Default Re: The joys of grinds: B16 Gearbox alternatives? (temp)
A little off topic.... Try running GM Sycromesh to see if it helps at all. It completely erased my second to third grind.
xthekidx
Jan 28, 2008 09:45 PM
Lsos
Feb 23, 2006 09:22 AM
Skinny_REX
Jan 21, 2006 02:24 PM
9200RPM
Nov 1, 2003 02:08 PM
1fstevo
Sep 3, 2002 01:43 PM
