Major Tuneup List (look good?)
Old Jan 6, 2004 | 05:44 AM
rkonfire's Avatar
Default Major Tuneup List (look good?)
Hey guys, I'm about to do a major tune up on my car which is at 119k. I wanted to double check my list with you guys and see if I've got everything or if some stuff should thrown out. Thanks.
1. Timing Belt
2. Water Pump
3. Balancer Belt and its 2 seals and inspect/adjust tensioner
4. Cam seals
5. Fuel filter
6. Valve Cover Gasket
7. PCV Valve
-Check oil pan gasket
-Check headgasket
Necessary?-Check rubber boots on the ball joints (upper and lower) and rear trailing arms (behind lower rear ball joint)
-Check all rubber fuel and brake lines
-Inspect and adjust accessory belts
-Inspect front and rear brakes
-Replace brake fluids including ABS
Old Jan 6, 2004 | 05:47 AM
LudeyKrus's Avatar
Sounds good to me; how do you expect to check the headgasket, though?
Old Jan 6, 2004 | 06:04 AM
noble4ws's Avatar
how about plugs and wires and air filter
Old Jan 6, 2004 | 06:18 AM
UA6 BALLER STATUS's Avatar
Default Re: Major Tuneup List (rkonfire)
Does anyone know how much 1-7 would cost you?
rkonfire's Avatar
Default Re: (noble4ws)
I already did those.
As far as checking the headgasket, I'm going to have everything done at a shop. Do you think the headgasket will be too much of a hassle/time consumer to check? I'm not a millionaire, and if it's going to take some time to do then I may as well pass since obviously nothing major is going on with it right now. :S
Old Jan 6, 2004 | 06:40 AM
LudeyKrus's Avatar
Well, unless you're losing compression from a blown headgasket, which you can check w/ a compression test, then I wouldn't touch it.
The only way to visually check a headgasket is to pull the head and look at it, but after that you'd have to replace it anyways since you can't reuse headgaskets.
Old Jan 6, 2004 | 07:33 AM
jc836's Avatar
Default Re: (LudeyKrus)
In the word of my dealer tech (23 years and counting)-it isn't broke-so don't touch it. The headgasket cannot be checked. You only need concern yourself with it if and only if there is evidence of a problem in either the head or bottom end. There is no real reason to check the torque on the headbolts for the same reason. What I would do if really concerned about engine condition would be to have them do a compression/leakdown test (~$100). There are a lot of Honda parts that can be quite old and still serviceable according to the experts I deal with.
Old Jan 6, 2004 | 09:57 AM
prelittlelude's Avatar
if it is a h22a1 then replace the autotensioner while you are in there. and if the bearings that the timing belt rides on are the original ones you might want to replace those 2, it would suck to do all that work then have you belt stear off to one side do to a bad bearing and then eat you head. so i would replace the auto tenssioner if your car is a vtec, and then check the bearings that the timig belt rides on and the balancer belt. when i did my timing belt at 120k my originaly bearings were done for.
Old Jan 6, 2004 | 11:58 AM
LudeyKrus's Avatar
got a pic or something that shows those bearings you're talkin about?
Old Jan 6, 2004 | 01:46 PM
noble4ws's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">got a pic or something that shows those bearings you're talkin about?</TD></TR></TABLE> id like to see what your talking about also
Old Jan 6, 2004 | 03:13 PM
Wiseguy619's Avatar
Default Re: (rkonfire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkonfire &raquo;</TD></TR><TR><TD CLASS="quote">I'm not a millionaire:S </TD></TR></TABLE>
Everything would be so much easier if we all were huh.
Old Jan 6, 2004 | 04:49 PM
rkonfire's Avatar
Default Re: (ProjectPenny)
It's an SI so I'm just having them check/adjust the manual tensioner. Now, these bearings you're talking about for the timing belt and balancer belt, can you go into more detail?
Old Jan 6, 2004 | 06:38 PM
junbb1's Avatar
dist. cap and rotor. valve adj. while the cover is off. and definatly a t-stat, it is 13 bucks-cheap insurance. also from the bottom of the car check your front engine mount, (the one off of the radiator support) especially if it is a 4th gen. they break all the time. check the operation of your fans. it is somewhat common for the condensor fan motor to go bad. i am guessing that you service the trans regularly.
dont forget to check your fuckle buckle valve and the muffler bearings. J/K
good luck.
Old Jan 7, 2004 | 07:25 AM
Matgallis's Avatar
I would replace these belts anyways. They aren't expensive compared to the water pump and the timing belt.
Old Jan 7, 2004 | 07:46 AM
Sephro's Avatar
Default Re: (junbb1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junbb1 &raquo;</TD></TR><TR><TD CLASS="quote">dist. cap and rotor. valve adj. while the cover is off.
good luck.</TD></TR></TABLE>
I was surprised no one said dist cap+rotor.
Also top off the blinker fluid
A coolant flush should be done yearly but you could do that at the same time allong with changing tranny fluid.
Old Jan 7, 2004 | 08:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noble4ws &raquo;</TD></TR><TR><TD CLASS="quote"> id like to see what your talking about also</TD></TR></TABLE>
numbers 18 and 10, the bearings that the timing belt and balancer belt ride on. mine were worn preatty badlly , sounded like a pair of fucked up rollor blades when you spun them. no grease left at all
Old Jan 7, 2004 | 09:12 AM
PhazedSI's Avatar
those "bearings" are your manual tensioner.
Old Jan 7, 2004 | 09:22 AM
Default Re: (PhazedSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhazedSI &raquo;</TD></TR><TR><TD CLASS="quote">those "bearings" are your manual tensioner. </TD></TR></TABLE>
thanks cheif, i had an h22 so they were actualy 2 seperate bearings. i know one of them is part of the h23 auto tensioner.
Old Jan 8, 2004 | 12:27 AM
rkonfire's Avatar
Well, I have an H23 so does the same rule apply Prelittlelude?
Old Jan 8, 2004 | 06:35 AM
yes , you should still check both of those bearings. both the h22 and h23 have timing belt and balancer belt , but the just use different tensioning devices.
jbell
Honda S2000
Oct 22, 2008 12:10 AM
RNPoo7
Aug 21, 2005 02:05 PM
MachAF
Jul 22, 2005 01:35 PM
jeremy.
Feb 8, 2005 10:42 AM
