Gas Tank swap for EG hatch
Old Jan 5, 2004 | 09:59 PM
dremmel's Avatar
Default Gas Tank swap for EG hatch
i got a 92 vx EG. soon installing a D15B vtec. Has any1 here successfully swapped a gas tank from a diff civic or Teg into their EG? i know my 92vx has a 10gal tank and the Ex/Si has 11.9. I would like to use a DC teg's tanke which is 13.2 i believe.... for LONG ROAD trips to VEGAS and Phoenix. Thankx
Old Jan 5, 2004 | 10:02 PM
=GAME='s Avatar
Default Re: Gas Tank swap for EG hatch (dremmel)
instead of all that labor, why dont you just fill up a portable gas container and bring it with you whenever you take road trips instead of driving around with a big *** tank daily?
Old Jan 5, 2004 | 10:04 PM
clm's Avatar
clm
Default Re: Gas Tank swap for EG hatch (O.G triple O.G)
It'll go in, but I forget what modifications are needed. There's another thread withthe same question a few lines down that might be of help, too.
Old Jan 5, 2004 | 11:10 PM
Tad's Avatar
Tad
if you care at all about weight reduction
(which you should.. you drive an eg) then stick with the small tank, a bigger tank will add alot of weight
I want to swap to a smaller one myself
Old Jan 6, 2004 | 09:32 AM
dremmel's Avatar
Default Re: (Tad)
weight reduction is not the deal, i have aVX daily driver. i just want a farther cruising range w/o the firehazard of a cell in the back. thanks for responses
Old Jan 12, 2004 | 08:28 PM
dremmel's Avatar
Default Re: (dremmel)
to the top
Old Jan 12, 2004 | 08:52 PM
piscorpio's Avatar
Hey dremmel, if you end up ditching that VX tank, would you consider sending it my way?
I have a huge dent in the bottom of mine that seems to have rust forming, and it has me a little worried.
Old Jan 12, 2004 | 11:57 PM
dremmel's Avatar
Default Re: Gas Tank swap for EG hatch (piscorpio)
you wanna pick it up? that would be too much $ to ship...and dangerous.. sorry
Old Jan 17, 2004 | 08:31 PM
dremmel's Avatar
if i can fit another tank successfully, $40 shipped? I'll just siphon the gas and box it up... UPS will ship anything i hear
Old Sep 24, 2004 | 08:05 PM
dremmel's Avatar
hmmm could i resurrect this thread? no gas tank swaps done???? how about an INTEGRA 94 & up gas tank into a 92 Civic hatch?
Old Sep 24, 2004 | 09:02 PM
jaM3s Bond's Avatar
Screw that
88 Crx HF with a 96+ HX motor (convert to OBD1 and use a VX Ecu) + EX/SI transmission = kinda quick car with 45+ MPG for under what ? 4,000 if you do it right
I want to build one of those in my spare time
Old Oct 2, 2004 | 09:03 AM
dremmel's Avatar
Default Re: Gas Tank swap for EG hatch (James Bond)
thats a great idea. i still have my VX ecu & wire harness. but i sold my Ex tranny last month . I was gonna put my VX tranny back in because my Dx tranny that is in right now, is slipping out of 2nd gear sometimes. well ill take a trip to the junk yard then!
Old Oct 2, 2004 | 10:05 AM
suspendedHatch's Avatar
I'm in east San Diego and I would like to swap your VX tank in place of my DX tank. How difficult is it anyway? Want to trade?
Old Oct 2, 2004 | 11:05 AM
HyBriDcxR's Avatar
A gas tank swap isn't worth it. That extra gallon of gas will net you a 30-50 extra miles depending on your motor.
Just use that money and fill up your tank when it's almost empty.
Old Dec 4, 2004 | 11:54 AM
igyloo's Avatar
Default Re: Gas Tank swap for EG hatch (HyBriDcxR)
bringing this back from the dead...
does a 2000 integra gas tank fit in a 1992 cx?
my problem is that the cx has rust forming on the top of the gas tank and i happen to have access to an integra tank.
repair or replace?
edit: found that it should fit
Modified by igyloo at 11:12 AM 12/4/2004
Old Dec 4, 2004 | 12:01 PM
Otherguy's Avatar
NASIOC.com
Default Re: Gas Tank swap for EG hatch (igyloo)
becareful if you do a tank swap like that, i know one of my friends was careless with his 96 dx hatch and his tank started to drag on the ground =\
Old Dec 4, 2004 | 12:42 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: Gas Tank swap for EG hatch (Otherguy92)
does anyone have a answer?
Old Dec 5, 2004 | 01:03 PM
igyloo's Avatar
Default Re: Gas Tank swap for EG hatch (Redline96LX)
https://honda-tech.com/zerothread?id=686717
Old Dec 10, 2004 | 12:12 PM
igyloo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have a answer?</TD></TR></TABLE>
just finished swapping mine, it fits perfectly
it also turns out, the entire tank was rusting, not just the top...
Old Jun 25, 2022 | 03:49 PM
Joven Greenaway's Avatar
Hey what tank did you use?
Old Jun 25, 2022 | 08:19 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
whitehf
18
Nov 4, 2011 12:02 PM
Sixfortyfive
Mar 25, 2009 12:43 AM
bdicustoms
Feb 22, 2004 10:24 AM
