short ram intake into stock air box
Old Jan 5, 2004 | 09:49 PM
piggs's Avatar
Default short ram intake into stock air box
(short ram intake into stock air box) has any one dun this if so how does it preform? Will a cone air filter fit inside?
I am thinking of doing this so that the intake is not pulling in so much hot air
Old Jan 5, 2004 | 09:58 PM
EGRhatch's Avatar
Default Re: short ram intake into stock air box (piggs)
when I bought my car, it had an AEM short ram going into the intake... it can't be bad, all you're doing is replacing the plastic tube with a metal one... and I dont think you can stick a cone filter in there, beside why would you want to
Old Jan 5, 2004 | 09:59 PM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by piggs &raquo;</TD></TR><TR><TD CLASS="quote">(short ram intake into stock air box) has any one dun this if so how does it preform? Will a cone air filter fit inside?
I am thinking of doing this so that the intake is not pulling in so much hot air</TD></TR></TABLE>
You mean so it's like an el cheapo Icebox? Someone on here has done it but using a stock-like panel filter instead of a cone filter; it's basically the stock setup but with the OEM tubing replaced by mandrel-bent tubing. That will probably work pretty similar to what you're thinking of. Then replace the stock filter with a K&N replacement filter and remove the airbox resonator.
Old Jan 5, 2004 | 10:15 PM
piggs's Avatar
Default Re: short ram intake into stock air box (EGRhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGRhatch &raquo;</TD></TR><TR><TD CLASS="quote">when I bought my car, it had an AEM short ram going into the intake... it can't be bad, all you're doing is replacing the plastic tube with a metal one... and I dont think you can stick a cone filter in there, beside why would you want to </TD></TR></TABLE>
no reason I was just wondering because i just bought a new filter. I ll just put a lay in filter in if I have any problems
Old Jan 6, 2004 | 03:45 AM
JimmyAtlantis's Avatar
If you're worried about the hot air, why not just get a heat shield???
Old Jan 6, 2004 | 11:29 AM
piggs's Avatar
Default Re: short ram intake into stock air box (JRI94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 &raquo;</TD></TR><TR><TD CLASS="quote">If you're worried about the hot air, why not just get a heat shield???</TD></TR></TABLE>
True But money is kinda tight so im lookin for in expense options. Ill look into it. You guys have any suggestions on heat sheilds
Old Jan 6, 2004 | 11:50 AM
Grimm's Avatar
heat shield what on the intake? on the filter right? heat shiedls don't really do much. I got some silly ractive filter w/ a heat shield on it, I'm sure it does alot I mean that piece of metal will definatly stop the hot air from getting in. It blocks it right Hot air CANNOT go around things called heat shields.
Sorry to be a dick but they don't work.
Old Jan 6, 2004 | 11:54 AM
boosted2point2ek's Avatar
Default Re: short ram intake into stock air box (Grimm)
if that is your problem i figure you can just rig up the intake into the air box.....injen makes a half-*** heat shield...also i have seen some home made heat shields also out of a piece of aluminum.
Old Jan 6, 2004 | 12:05 PM
pdiggitydogg's Avatar
I personally really want to do this but dont have the ***** to cut up my akimoto
Old Jan 6, 2004 | 12:16 PM
piggs's Avatar
Default Re: short ram intake into stock air box (ghettocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghettocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">if that is your problem i figure you can just rig up the intake into the air box.....injen makes a half-*** heat shield...also i have seen some home made heat shields also out of a piece of aluminum.</TD></TR></TABLE>
Do you have any pics
Old Jan 8, 2004 | 09:12 AM
if you look in the newest issue of HCI they have 150 tech tips...and it is in there...not sure what number it is
Canadian_EF
Apr 20, 2009 09:26 AM
mitcho
13
Jul 12, 2007 05:39 PM
Iomega01
Aug 9, 2005 12:51 PM
4DRmafia
14
Sep 26, 2004 07:35 PM
csfalcon
Aug 18, 2002 08:54 AM
