maintenance light
Old Jan 5, 2004 | 08:49 PM
NaSh123's Avatar
Default maintenance light
anyone know what service is done around 53,000 miles? becuase the maintenance light is on yellow right now and its gonna turn red soon. I wanna see what needs to be done so maybe I can do it with my friends try to convince my dad we can do it lol instead of taking it to dealer and having them charge me 300 :-)
Old Jan 6, 2004 | 05:09 AM
Grimm's Avatar
Default Re: maintenance light (NaSh123)
check out the manual... probably just an overall look over, belts, fluids, brakes, plugs, tire rotation that sort of stuff...
Old Jan 6, 2004 | 06:14 AM
JICEK9's Avatar
probobly a 60k maintance.
spark plugs, all your fluids, check/adjust brakes, valve adjustment, 60 point inspection etc...
Old Jan 6, 2004 | 06:21 AM
westsidejdmyo's Avatar
Default Re: maintenance light (JICEK9)
and most importantly your cam belt will need changing soonish
Old Jan 6, 2004 | 06:38 AM
JICEK9's Avatar
Default Re: maintenance light (westsidejdmyo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by westsidejdmyo &raquo;</TD></TR><TR><TD CLASS="quote">and most importantly your cam belt will need changing soonish</TD></TR></TABLE>
that doesn't get done till 90k
Old Jan 6, 2004 | 06:47 AM
hondachick81's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote">probobly a 60k maintance.
spark plugs, all your fluids, check/adjust brakes, valve adjustment, 60 point inspection etc...</TD></TR></TABLE>
ditto....
and you really don't need to go by the maintenance light.
mine starts to turn orange like every 15k ....I usually do maintenance far more often then an owners manual would state...plus depending on how hard you are to your car.
definately check your belts too
Old Jan 6, 2004 | 08:27 AM
kommon_sense's Avatar
Default Re: maintenance light (civicgirl114)
That maintenance indicator turns red every 7500 miles unless it is reset. No major service done at 53k. Just do your regular service (oil change, rotate tires, inspect brakes, etc.) and reset the light yourself. Just remember, all big service is done at 30k intervals. You have more inspection type service at 15k intervals.
Old Jan 6, 2004 | 02:27 PM
NaSh123's Avatar
Default Re: maintenance light (kommon_sense)
i c thanks where do i reset the service light myself? never done that before becuase i changed oil about 1000 miles ago so thats fine and i had a major service done around 45,000 mile with all fluids flushed and re-filled with all other things done as well
Shaynepolevault
Apr 1, 2008 01:57 AM
s2kkk
Honda S2000
10
Aug 12, 2007 12:27 PM
lovemichelle
15
Jun 22, 2006 11:54 AM
"Hites"
Apr 3, 2005 12:35 PM
coot_er
Acura TL, RL & ZDX
Nov 27, 2004 11:42 AM
