99 lx-ex swap, o2 problem
ok i swapped a 99 ex motor into a lx, swap went real easy. when i went to run the second o2 (wich is totaly different then a damn lx) i ran into some problems. its throwing this code, p0141 bank 1 sensor 2 heater circut. i tried hooking it up right and cleared codes. came back. i tried bypassing it. came back. The shitty thing is the sensor reads correctly, but still sends the code....
so basically, how do i get rid of this damn code, is there any way to either bypass the second o2, or is there something i am missing when i hooked it up?
yes i am running the stock ex exhaust for now, had the entire car, (rollover), swapped everything over. everything is in my car the way it was in the ex.....
it is the o2 made for that motor/car, like i said EVERYTHING from the ex was transfered to the lx. thats why i dont understand y its throwing this code, i tried a new o2, no luck, im going to try a new brain it seems that the wire thats supose to be grounded is giving power. so if that doesnt work, i dont know what to try next.
NEVERMIND.... THANKS FOR NOTHING!!!!! j/k. i figured it out... the damn ecu was messed up.... pluged in a different ecu and it works perfectly....
jorober5
Feb 9, 2006 04:40 AM
good deal .... the ecu is hardly suspected
