You guys ever heard of this?
Old Jan 5, 2004 | 06:13 PM
pbcdb's Avatar
Default You guys ever heard of this?
http://cgi.ebay.com/ebaymotors...21332
I was wondering about the Hub Centric Ring itself. Is it a must have? Just wondering cause I notice vibration in my car after installing my slips and have gotten the balance of the wheels checked and they are balanced. My mechanic can's seem to figure it out and maybe this would be the solution. BTW the vibration occurs between like 65 and 75 after and before that it is fine.
Old Jan 5, 2004 | 06:15 PM
The Internet Tough Guy's Avatar
Default Re: You guys ever heard of this? (pbcdb)
yeah you should get a set of those - it will definately eliminite your vibrations. i got mine from http://www.prestigewheel.com they were 40 shipped. those ones you've got there are metal and can sieze on the hub. get some polycarbonate ones that wont to that or melt.
Old Jan 5, 2004 | 06:17 PM
pbcdb's Avatar
Wow nothng like wastin 100 dollars on alignment and re-balancing. God I hate wasting money!!!!!!
Old Jan 5, 2004 | 06:19 PM
pbcdb's Avatar
BTW would anybody happen to know the size I need for my slipstreams on a civic.
Old Jan 5, 2004 | 06:21 PM
HATCHingMN's Avatar
Default Re: You guys ever heard of this? (jwn7)
Got mines at discounttires for $5 buck
Old Jan 5, 2004 | 06:22 PM
Si Arn's Avatar
Default Re: You guys ever heard of this? (HATCHingMN)
Do all kinds of rims need them? Say 5Zigens?
Old Jan 5, 2004 | 06:23 PM
pbcdb's Avatar
oooo I like that price
Old Jan 5, 2004 | 06:26 PM
deeksmooth's Avatar
Default Re: (pbcdb)
i have rota slips 5 lug, u think i need them?
Old Jan 5, 2004 | 06:32 PM
Default Re: (citrEK)
if you have aftermarket wheels, you should get them. it's not completely necessary, but you'll feel damn stupid if your lugs work their way off. without them, all of the stresses your wheel takes are being absorbed on your wheel studs; with them, the stresses go onto the hub like they are supposed to. without the rings, you should retorque your lugs every 100 miles, and you will get unwanted vibrations at highway speeds. just get them... don't be stupid and cheap.
the diameter of the hub on all civics is 56.15mm, and the diameter of the centerbore on my rotas was 67.1 mm. the smallest i could find at tire shops was 72 mm - you'll probably need to get them from http://www.prestigewheel.com .
Old Jan 5, 2004 | 06:34 PM
HATCHingMN's Avatar
most after market rims are universal application, so it needs them rings
Old Jan 5, 2004 | 06:35 PM
pbcdb's Avatar
Thx for the great info
Old Jan 5, 2004 | 06:37 PM
pdiggitydogg's Avatar
check your rim for the inside hub size (i believe mine was73 on my c8's) and then put in the civic size
they are practically essential
Old Jan 5, 2004 | 06:38 PM
Si Arn's Avatar
Default Re: (HATCHingMN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN &raquo;</TD></TR><TR><TD CLASS="quote">most after market rims are universal application, so it needs them rings </TD></TR></TABLE>
awesome... I have freeway vib's last summer. This is likely why! Thanks!
Old Jan 6, 2004 | 10:35 AM
pbcdb's Avatar
Where on the rim would the diameter of the centerbore be? I took a rim off and I dont see a mm measurement.
Old Jan 6, 2004 | 10:39 AM
deeksmooth's Avatar
Default Re: (pbcdb)
ditto, my slipstreams are sitting in my house... nothign there... cept for 1670 and 45... which is rim specs.
Old Jan 6, 2004 | 11:28 AM
pbcdb's Avatar
Hey dude I just went to discount tire and they had them my slips were 67mm. Were 10 dollars if you were wondering.
Old Jan 6, 2004 | 11:30 AM
dwnthehatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 &raquo;</TD></TR><TR><TD CLASS="quote">those ones you've got there are metal and can sieze on the hub. </TD></TR></TABLE>
All the polycarbonate ones I used ended up getting heat stress cracks. I used anti-seize compound on my metal ones to prevent seizing. No problems yet.
Old Jan 6, 2004 | 02:23 PM
its on the side of the box on the tag and on the wheel's sticker (which you covered up with the tire, more than likely)
Old Jan 6, 2004 | 02:26 PM
deeksmooth's Avatar
Default Re: (pdiggitydogg)
i checked the sticker on the inside of the rim w/ of my rota's, not there... i called machiii.net and they were able to tell me that mine is 73mm on my rims...
still need to know how to measure my hub...
https://honda-tech.com/zerothread?id=724760
daygobaker
Mar 26, 2011 10:01 PM
trigun7469
16
Oct 31, 2003 06:16 PM
Heath
Mar 19, 2003 07:23 PM
