B16 Gen I and Gen II Part/Block Differences?
Old Jan 5, 2004 | 04:36 PM
b16ingp's Avatar
Default B16 Gen I and Gen II Part/Block Differences?
Car: 1991 Honda Civic with JDM B16 Gen I
I am wondering what parts are different on these engines from Gen I too Gen II, And weither there are many differences from JDM or USDM?
I am mainly needing to know what I need to say my car is when buying parts such as
Headgasket Kit
Oil pan
Starter
Alternator
Water Pump
Thermostat
Block Heater
I had tried buying a block heater here for a 99 DOHC civic it was around the same size, but the threads to fine on the block heater they gave me.
I also tried buying a new thermostat and stated the 99 DOHC and it was way to small to fit.
Can anyone help with this? Fiasco..... I love the jam my car has with this engine, But living way up north in canada am having trouble finding any info on a Gen I jdm b16.
Perhaps I will have to buy a 02 civic hatch and drop in a JDM K20A Type R
Old Jan 5, 2004 | 05:31 PM
Rywire's Avatar
Default Re: B16 Gen I and Gen II Part/Block Differences? (b16ingp)
purchase engine parts for a 94 del sol dohc vtec. Ryan
Old Jan 5, 2004 | 06:03 PM
f@sth@tch89's Avatar
Default Re: B16 Gen I and Gen II Part/Block Differences? (droppedcrxsi)
I would buy all the stuff for the GEN 1 block. One difference that i can say is that on the 92-95 b16 the temp. sensor is on the thermostat housing unlike the gen 1 which is on the head. I think everything should plug up. Im using a 88-91 Si harness on my motor(99 b16a2/ '00 GSR head)...im not running an alternator, yet.
IMO water pump, alternator, and starter shouldnt matter as long as it is for a dohc vtec motor.
Old Jan 6, 2004 | 06:12 PM
b16ingp's Avatar
Does anyon have anymore input?
Old Jan 6, 2004 | 06:38 PM
fourthgenhatchB17's Avatar
Default Re: B16 Gen I and Gen II Part/Block Differences? (fasthatch89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatch89 &raquo;</TD></TR><TR><TD CLASS="quote">I would buy all the stuff for the GEN 1 block. One difference that i can say is that on the 92-95 b16 the temp. sensor is on the thermostat housing unlike the gen 1 which is on the head. I think everything should plug up. Im using a 88-91 Si harness on my motor(99 b16a2/ '00 GSR head)...im not running an alternator, yet.
IMO water pump, alternator, and starter shouldnt matter as long as it is for a dohc vtec motor. </TD></TR></TABLE>
Alternator may not mount up differently but i dont think you can use a 99-00 obd-2 B16 alternator on a first gen obd-0 B16 car. I believe the electronics are different as well as the plug. Water pump should be the same thing. Starter may be different than a 99-00 B16 car because of the hydro trans, so just to be safe use a 90-93 teggy one. Someone correct me if im wrong on any of this info.
Old Jan 6, 2004 | 10:31 PM
Rywire's Avatar
OK,
alternator=90-91 teg(almost certain)
starter=90-91 teg(almost certain)
headgasket=del sol dohc vtec(certain)
oil pan=del sol dohc vtec(almost certain)
water pump=del sol dohc vtec(certain)
thermostat=del sol dohc vtec(certain)
block heater=del sol dohc vtec
in general, engine parts are del sol dohc vtec, tranny, ignition parts, and other accesories are teg. This is not a deffinate list, but should be correct. Ryan
Old Jan 7, 2004 | 07:30 PM
b16ingp's Avatar
Thank You Guys.
I found for sure the threads are different on a 1999 b16 civic.
lol, hopefully a del sol one will work.
Old Jan 7, 2004 | 07:37 PM
4crx4me's Avatar
Post this in the tech or hybrid forums. Or search in the archived topics for Katman posts. ( he's an engine ID guru. LOL)
HTH
Old Jan 8, 2004 | 03:32 PM
mad2nr's Avatar
Default Re: B16 Gen I and Gen II Part/Block Differences? (4crx4me)
u can either use the del sol parts or 99 si parts. they r all the same except for the alternator likewas mentioned b4. different obd's. the starter however im not sure. i dont think honda used a plug for the starter. its just the positive o-ring connector and the female slide connector. i used all 99 si parts becuz a couple of my friends work at several dealers. good luck
Old Jan 8, 2004 | 04:51 PM
-KangaRod-'s Avatar
I got a block heater for a 92 Integra GsR and that worked for me.
b16ajdmrex
Northeast (Sales)
Oct 1, 2010 07:02 AM
r_spec
Oct 19, 2004 05:21 PM
~ZoSo~
Apr 21, 2003 07:30 AM
Fatty_1775
Jan 14, 2003 05:39 PM
