The lighter the rim the better?
Old Jan 5, 2004 | 04:18 PM
trooper0641's Avatar
Default The lighter the rim the better?
I have si's on me right now...and i would like to know if switching to hx's would make me faster.
Having the lighter rim...hxs... 14" size...shouldnt the wheels spin faster than the 15" si's?
Since lighter is better...would i be able to brake better / faster with the hxs instead of the si's?
Si's are bigger? So more grip?
Is it worth it? Switching to hxs?
Old Jan 5, 2004 | 04:21 PM
Ricey McRicerton's Avatar
Default Re: The lighter the rim the better? (trooper0641)
Yes, a lighter rim will make you faster. You can put a 195 series tire on an HX for sure, and I *THINK* a 205 will fit on there. You can put a 205 series on a Si as well, so there really isnt any more grip. HXs will give you performance gians.
Old Jan 5, 2004 | 04:22 PM
KiDSoL's Avatar
They spin the same just less stress on your motor.
Old Jan 5, 2004 | 08:11 PM
Default Re: The lighter the rim the better? (Gumtape_Deathmatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gumtape_Deathmatch &raquo;</TD></TR><TR><TD CLASS="quote">to put it simply, a smaller lighter wheel will give you better acceleration. It is a benefit to your car to decrease your unsprung weight. A larger diameter wheel will give you a bit more when going for max mph.
guess which one i suggest. </TD></TR></TABLE>
the lighter wheel...because who needs to run 120 mph?
Old Jan 5, 2004 | 08:22 PM
HXvtec's Avatar
get the hx's. i was stupid for letting mine go but i needed money. when i used to have my hx rims i had way better acceleration. 17 are just more drag on your motor becuase it takes more power to get the wheels to turn.
Old Jan 5, 2004 | 08:40 PM
supaZZZleepa's Avatar
hx's are bomb...if you want grip you have to get better tires...if you want to race on the streets nitto 555 are good..but shouldnt be driven daily (especially in the rain)
Old Jan 5, 2004 | 09:50 PM
clm's Avatar
clm
Default Re: (supasleepa)
If you can pretty much get an even trade with your Si rims for HX rims, then go for it, other wise I wouldn't bother. IMO, the benefits aren't good enough to warrant a big effort since it's just for the street.
michaelprice83
Dec 14, 2008 08:12 PM
lil_kev
Mar 31, 2008 05:58 PM
BLUE EH3
Dec 29, 2006 11:17 PM
low430
Sep 27, 2005 08:45 PM
Mr. Softee
Dec 26, 2001 05:03 PM
