JUN 3 idle?
Old Sep 26, 2001 | 06:54 PM
itr501's Avatar
Default JUN 3 idle?
Quick question: whats the idle for jun 3's?
Old Sep 26, 2001 | 06:57 PM
Leo95SE's Avatar
Default Re: JUN 3 idle? (itr501)
stock idle.. 650-700 rpm..
same idle, valve lash, and cam timing as stock.
Mike M's Avatar
Founding Member
Same as stock
Old Sep 26, 2001 | 07:34 PM
t's Avatar
t
Default Re: JUN 3 idle? (Leo95SE)
I thought stock idle was 800??
Old Sep 26, 2001 | 09:16 PM
alexboy's Avatar
Default Re: JUN 3 idle? (t)
how do the jun three compare to the toda b's idle wise (i have already seen the importreview) who here uses jun 3's how streetable are they
Old Sep 27, 2001 | 12:34 AM
GZR4DR's Avatar
Default Re: JUN 3 idle? (alexboy)
Toda B's equal a kinda rough idle. It can be smoothed a little with an apex vtec controller. Jun 3's idle like stock.
Old Sep 27, 2001 | 05:13 AM
Leo95SE's Avatar
what does streetable mean? torque down low?
they idle like stock and are race cams. therefore they make most power above 7k.
if you are looking for a torquey streetable cam, use the itr or ctr.
Old Sep 27, 2001 | 06:43 AM
GraphiteAccord's Avatar
i would even go as far as saying go with toda A's, more cam, and you can still use itr vavle train to 9100.
Old Sep 27, 2001 | 08:45 AM
BoM's Avatar
BoM
Default Re: JUN 3 idle? (GraphiteAccord)
yeah streetable means more power at low end and midrange, the powerband u usually drive at...but for some people like me, i use the top end....u'll always hear my vtec after a light...but i dont' have an exhaust yet soo its alll about the AEM syndrome...
Old Sep 27, 2001 | 08:49 AM
AllMotorMadness's Avatar
jun 3's has a pretty good idle is what i've been hearing but wouldn't know until my motor is put together
Old Sep 27, 2001 | 09:04 AM
Big Phat R's Avatar
All high-lift long-duration cams have lopey idles - it's because they don't generate a lot of vacuum.
I have Spec B's and they idle fine once the motor is warmed up. It usually idles around 800-900 rpm.
Old Sep 27, 2001 | 10:07 AM
B18CXr's Avatar
B idle is music to the hears, III's are barley noticable.
Kinda like Clutch versus Backstreet Boys or 5 Times Down versus J-Low.
Old Sep 27, 2001 | 12:00 PM
PrjctDC2-R's Avatar
New User
Default Re: JUN 3 idle? (Big Phat R)
what about Toda Spec C idle? ok to run on the street?
Old Sep 27, 2001 | 12:03 PM
Big Phat R's Avatar
Default Re: JUN 3 idle? (PrjctDC2-R)
Spec C's are not a drop in mod - but yes they are streetable - but the idle will be lopey like the B's.
Old Sep 27, 2001 | 12:05 PM
alexboy's Avatar
what is the average vtec crossover on the jun3's also what would it be on the jun2's
Old Sep 27, 2001 | 12:10 PM
PrjctDC2-R's Avatar
New User
lopey idle is the ****! scare off some rustangs >
Old Sep 27, 2001 | 12:15 PM
Leo95SE's Avatar
jun recommends 5800 i believe.
ive used from 5500 to 6500. i like around 5700 the best, as long as you have HIGH compression, otherwise, dont cross over until 6500-7000, not enough pressure to feel a big difference before then.
Old Sep 27, 2001 | 01:39 PM
ImportReview
Guest
Posts: n/a
JUN 3's idle perfectly. YOu can't even tell the car has aftermarket cams in it.
Toda cams...thats a tough one. If you put them in and don't have a minimum V-AFC, your not going to idle well.... with Hondata youll idle pretty good, with V-AFC its pretty decent.
JUN 3's...and streetability....
I rate them a 7.
Toda B's for streetable..I rate them an 8.
Toda A's for street, I rate a 9.
Type-R cams I rate a 10. They are what every other street cam is compared to. Great mid range power to 8k.
You won't need JUN cams unless your rev to 9k. Cause out of all the cams listed, they will peak the latest.
JUN type 2 cams are actually some great cams. Great. And you can use them with stock Type-R valvetrain and ECU. Great cams. I rate them a 9+.
Jeff
Old Sep 27, 2001 | 02:39 PM
alexboy's Avatar
Default Re: JUN 3 idle? (ImportReview)
i change my mind like my draws (very often) i think the jun2's are what i am looking in the direction of for the simple reasons less tuning, nicer idle, nice power gains, very streetable
Old Sep 27, 2001 | 03:51 PM
ImportReview
Guest
Posts: n/a
I change my mind more than most people too.
I think 1 product is good....then i look at some more comparable products...then i think product #1 that I thought was good...is not so good and just average...and so on and so forth.
It also took me a little bit to figure out how each cam performs in the mid range. This also changed my mind of what is good for certain things and what is bad.
All I can tell you is...the best cam for the street if probably not even in the top 5 for the drag strip.
It took me about a good 9 months of good study to learn about the cams for the B series motor from alot of different companies. And I am still open to change my mind if I learn something new...and I am looking for new things constantly.
Jeff
Old Sep 27, 2001 | 03:57 PM
SpoonCivic's Avatar
New User
whoa ur guys cars idle at 800-900rpm
i have the b18c5 and i idle stoich at 1000rpm when its warm...1500rpm when its cold
whats wrong with this picture
Old Sep 27, 2001 | 04:01 PM
ImportReview
Guest
Posts: n/a
Default Re: JUN 3 idle? (SpoonCivic)
get a screwdriver and adjust idle screw in TB...problem solved and your picture is back to normal.
Adjust screw IN..tighten it.
EF_LSVtec
12
Jun 28, 2003 05:29 PM
TaboR
Apr 9, 2002 12:52 PM
Montreal R
Apr 2, 2002 10:47 PM
HX_Guy
Dec 13, 2001 01:47 PM
amrintegra
Dec 9, 2001 12:18 PM
