integra code 43? fuel supply system
Old Jan 5, 2004 | 01:31 PM
chpracing's Avatar
Default integra code 43? fuel supply system
anyone ever having problems with this code?..see if im missing something...changed regulator,cat,injectors,fuel filter,ecu..pressure is high at 60psi but see no kings or line problems...pump maybe?..just curious to get some input.easy to over look the easy things sometimes
Old Jan 5, 2004 | 03:07 PM
EG-lowrider's Avatar
got the same damn code on my eg, had it for about 6 months now, now has 190,000 on it and starting to run like ****, tried everything to get rid of the code, cant figure it out though. did you ever mess with your idle air control mixture screw, mine happened after messing with mine, or mabey just a coinsodence.
Old Jan 5, 2004 | 04:30 PM
chpracing's Avatar
Default Re: (Broke@$$tuner)
yea..i get a bad idle in the mornings and then it runs perfect...im stumped
Old Jan 5, 2004 | 08:47 PM
blackeg's Avatar
Default Re: (chpracing)
oxygen sensor- check the o2 sensor and make sure its working correctly.
Old Jan 6, 2004 | 08:22 AM
chpracing's Avatar
Default Re: (blackeg)
brand new o2 also
Old Jan 7, 2004 | 05:06 AM
Cole D's Avatar
was it universal sensor make sure you have it wired correctly I got a code 43 went through the same problem you did..... to find out the 02 sensor was wired wrong
Modified by Barney Ruble at 5:17 AM 1/19/2004
Old Jan 7, 2004 | 12:14 PM
chpracing's Avatar
its a 1 wire o2..thanks though
~sp33~
13
Jan 14, 2009 12:30 AM
PWRDbyHseries
Feb 22, 2006 04:53 PM
alberto.garrido
Jul 27, 2004 09:33 AM
hatchedzex
May 24, 2004 05:12 PM
95civicracer
Nov 21, 2003 10:29 AM
