swirl marks on car, what to do?
Old Jan 5, 2004 | 12:16 PM
speedehatch's Avatar
Default swirl marks on car, what to do?
I have that OEM purrple honda color. Amthest pearle i think. I have a lot of swirl and light scratch marks. They can only be seen an certain angles in the sun but it bothers me. I have tried that scratch x stuff and it doesnt work. Can i take it to a paint or detailing shop and have them clean it up to remove all the swirl marks without havng to repaint the car? How much does this usually cost?
Old Jan 5, 2004 | 12:22 PM
The_Todd's Avatar
Farts in the shower
Default Re: swirl marks on car, what to do? (speedehatch)
Usually a buffer some elbow grease and some wax does the trick.....or you can go to a detail shop and they can do it for you, usually around 50-100bucks.
Atheist's Avatar
Yea they will just sand it and use a buffer with a polishing compound, will prolly cost about 125 bucks.
Old Jan 5, 2004 | 02:27 PM
B18bEK's Avatar
i think Mothers or Meguiars makes a product called swirl mark remover, try that and then a fresh coat of wax
Old Jan 5, 2004 | 03:07 PM
haccord2.2's Avatar
Default Re: (B18bEK)
Ok it seems like every car I buy or my family buys has been detailed and the detail shop put swirl marks in it with a rotary buffer or orbital buffer. This can be fixed pretty easy for under $20.00. You will want to buy some Meguiar's Mirror Glaze Professional Swirl Remover Deep Gloss Cleaner/Polish #9. Then after washing the car and drying it start applying it by hand with a cotton terry cloth towel or a foam applicator pad and work in a small area at a time and you have to put in some elbow grease and you must work the swirl remover liquid until it nearly dry. Then just let it sit for a minute and then with a new clean cotton terry cloth towel buff the remander, then I use Meguiars Mirror Glaze Professional Hi-Tech Yellow wax #26 last to finish it off and that should take care of it. Well this has never let me down so far, and I have done alot of swirl marks so I hope this helps you out.
DarkBB4
Apr 26, 2005 10:52 AM
Full Race A6
Apr 30, 2004 06:49 AM
DANgerous
Apr 3, 2004 09:50 PM
redteg1
Feb 23, 2004 12:00 PM
Mark
Jun 19, 2003 03:12 PM
