02 sim AND a/f gauge. will it work?
I'm asuming that your car is equipt with two o2 sensors, the one that hooh the sinulator up to will be the secondary the one in the cat, so the af guage should be hooked ut to the primary, the one before the cat, and if your car is only equipt with o2 sensor, you should not a simulator,you need an 02 sensor.
yes you are coorect!<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smurfey002 »</TD></TR><TR><TD CLASS="quote">ok, so the a/f gets hooked up to the primary sensor(the one before the cat) and the sim would be hooked up to the secondary, the one in the cat/testpipe. and yes, my car has two 02 sensors. </TD></TR></TABLE>
