Doing a b18b1 swap into a 94 civic. AC Question???
hi,
I have a B18B1 complete swap with AC unit to put into my civic hb. My civic hb has AC too. What should I do? Keep the AC unit that comes with the B18B1 or keep the civic AC unit? Will the AC hoses, belt, and connections be interchangeable? Any thoughts or comments? Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Poey2 »</TD></TR><TR><TD CLASS="quote">hi,
You can still use your A/C compressor off of your EG along with the belts...considering the belt tension can be adjusted. And about the mounting bracket, you can too use the EG's but only 2 of the 4 bolts will line up. If you want to be on the "politically correct" side, use the A/C bracket off of a del Sol DOHC VTEC. There, all 4 bolts will be used.
See Are X
Jun 5, 2007 11:15 AM
