LS engine motor sounds really bad...i need help quick
Old Jan 5, 2004 | 07:36 AM
BrokeAssAcura's Avatar
Default LS engine motor sounds really bad...i need help quick
My engine, while accelerating, has been stuttering more and more as I drive it. I bought some engine cleaner (gumout 75,000+ miles) and will see if that helps when I get low on gas, but I'm afraid that the cleaner won't really help it. Any other ideas as to why it might be doing that would be awesome. BTW...my car has 151,000 miles on it and is a 1994. Thanks.
Old Jan 5, 2004 | 08:05 AM
1998_4dr_gsr's Avatar
Default Re: LS engine motor sounds really bad...i need help quick (BrokeAssAcura)
Try tuning it up, or do a compression test.
Old Jan 5, 2004 | 08:45 AM
Devlins 91LS's Avatar
Default Re: LS engine motor sounds really bad...i need help quick (1998_4dr_gsr)
Wow that could be a LOT of problems.
I'd say take off your distributor cap & rotor and change those. Those sound like the culprit if its been getting "worse and worse" every time you drive it.
Old Jan 6, 2004 | 05:11 AM
Default Re: LS engine motor sounds really bad...i need help quick (Devlins 91LS)
Well, I also remembered my O2 sensor might be smashed from when I removed the heat sheild a few months back. Would that have anything to do with it?
Old Jan 6, 2004 | 05:38 AM
Rod.'s Avatar
It might be because that tells the ecu what to do
Old Jan 6, 2004 | 08:08 AM
1INTEGRA's Avatar
New User
Sounds like your spark plugs are going bad or you distributer isn't producing enough spark. When my LS did that I had to by a new distributer.
Modified by 1INTEGRA at 7:33 PM 1/7/2004
Old Jan 8, 2004 | 12:53 PM
Default Re: (1INTEGRA)
hey, i've checked the distributor and that works as far as i can tell...would it be possible that the timing belt is shot?
Old Jan 9, 2004 | 12:55 PM
1INTEGRA's Avatar
New User
Usually when the timing belt goes out the engine just dies or runs bad for a few minutes then dies because your cams aren't spinning and no air is getting in or out of the engine.
But anything is possible.
KeithDigital
Apr 4, 2009 04:02 PM
joshnmelissa
10
Feb 6, 2008 05:07 PM
B204door
Jul 26, 2007 11:23 PM
bumsta217
Aug 31, 2003 11:57 AM
