92 CX Fuel Pump ?
Old Jan 5, 2004 | 07:33 AM
vtecb20coupe's Avatar
B A N N E D
Default 92 CX Fuel Pump ?
ok, on a 92 civic cx, my friend has a b16 swap in it. yesterday, the car wouldn't start a few times. you could tell it was getting plenty of spark but like it was out of gas. when you turn the ignition to on, but don't start it , sometimes you can't hear the fuel pump cut on. it has plenty of gas cause he just filled up. this should mean it's going out, correct? if it is, does this mean he needs to changeout the in-tank pump and change the fuel filter while he's at it or something else?
Old Jan 5, 2004 | 07:41 AM
Mikey3000's Avatar
Default Re: 92 CX Fuel Pump ? (vtecb20coupe)
if u cant hear it turn on, then its on its way to the *******. swap it out for a better one. u dont have to change the fuel filter while your at it, it has nothing to do with it.
Old Jan 5, 2004 | 08:13 AM
B A N N E D
Default Re: 92 CX Fuel Pump ? (Mikey3000)
which oem pump will he be able to use for the b16a and possibly a ls/vtec setup?
Old Jan 5, 2004 | 08:27 AM
owen_the_soyboy's Avatar
dohc vtec pumps are different from the others.
you can drop in any integra/civic pump but the dohc vtec units are more capable of handling the B16 he swapped in.
Old Jan 5, 2004 | 08:58 AM
dunkd's Avatar
Default Re: 92 CX Fuel Pump ? (owen_the_soyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by owen_the_soyboy &raquo;</TD></TR><TR><TD CLASS="quote">dohc vtec pumps are different from the others.
you can drop in any integra/civic pump but the dohc vtec units are more capable of handling the B16 he swapped in.</TD></TR></TABLE>
Old Jan 5, 2004 | 11:07 AM
mmuller's Avatar
Mad Scientist
Default Re: 92 CX Fuel Pump ? (dunkd)
d series pumps=79 lph
b-series vtec=135 lph
Old Jan 5, 2004 | 06:22 PM
dunkd's Avatar
Default Re: 92 CX Fuel Pump ? (mmuller)
what about dseries vtec pumps are they still 79?
Old Jan 6, 2004 | 05:21 AM
B A N N E D
i believe that is what they were referring to.
Old Jan 8, 2004 | 07:37 AM
ARIZONA's Avatar
NOT trying to thread jack, but I was just searching for this......
? Is a CX stock FP capable of supplying a fully built 10.5:1 CR D16Y8? This is such a dumb question, I know. But I never really thought about it till now and I assumed all D series pumps were the same, VTEC or not? I just did this swap yesterday anyway, so it was planned to change it out this weekend.
logjammin
17
Jul 29, 2013 07:59 AM
92lx
Sep 28, 2011 11:30 AM
eastbay92cx
Oct 8, 2004 06:41 PM
SupaFly_Honda
Oct 13, 2003 05:09 PM
Patron
Apr 17, 2003 03:28 PM
