what color wire on MAP sensor goes where? obd1
Old Jan 5, 2004 | 05:25 AM
civicracer1993's Avatar
Default what color wire on MAP sensor goes where? obd1
i know where they go on ecu but which color goes to what? i have a 93 DX harness?
Old Jan 5, 2004 | 09:07 AM
xenocron's Avatar
Default Re: what color wire on MAP sensor goes where? obd1 (civicracer1993)
On my ODB0 MAP:
Black wire = ground (constant 0 volts)
Red wire = constant 5v power (constant 5 volts)
Green wire = MAP output voltage (variable voltage)
Im pretty sure all Honda MAP sensors follow the same principle tho...regardless of OBD version
Old Jan 5, 2004 | 09:42 AM
turboxsi's Avatar
Default Re: what color wire on MAP sensor goes where? obd1 (xenocron)
The '93 harness is a obd-1 harness and i believe the colors are different from the obd0 harness plug for the map sensor.
Here's my obd-1 MAP sensor plug wire colors and there pinouts:
white--> D17 MAP Sensor Input About 3v
yellow/green--> D19 Reference Voltage About 5v With key on, engine off
green/blue--> D21 Sensor Ground Less Than 1v
Old Apr 25, 2010 | 06:13 PM
evo500's Avatar
this helped me out!
ashb82
Jul 22, 2012 12:49 PM
97EKCRVtec
Aug 18, 2009 11:36 AM
itslogz
Mar 20, 2008 08:24 PM
Gant
May 18, 2005 08:47 PM
SiR HatchAlot
Jan 11, 2004 08:50 PM
