Converting a odb2 Distributor to a odb1 Distributor
Old Jan 5, 2004 | 03:38 AM
BLUE EH3's Avatar
Help we my pennies
Default Converting a odb2 Distributor to a odb1 Distributor
i need a Distributor for my odb1 car/motor. my boy is sellin a 0db2 Distributor for cheap. i know there are posts about this, but i am havin a hard with the search. i know a odb2 Distributor can used on a odb1 motor/car. what has to be done, rewired, cute and so forth.
Old Jan 5, 2004 | 03:50 AM
Maintenance's Avatar
Default Re: Converting a odb2 Distributor to a odb1 Distributor (BLUE EH3)
Old Jan 5, 2004 | 04:01 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: Converting a odb2 Distributor to a odb1 Distributor (racerxfear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerxfear &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE> only half the pics shows up
Old Jan 5, 2004 | 04:21 AM
BLUE EH3's Avatar
Help we my pennies
THANK U
Old Jan 5, 2004 | 12:27 PM
BLUE EH3's Avatar
Help we my pennies
picked it 2day 4 30bucs
Old Jan 5, 2004 | 01:49 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Dude you only have to repin TWO wires, and they are color-coded:
Pics by me.
Old Jan 5, 2004 | 02:39 PM
eh2's Avatar
eh2
Default Re: Converting a odb2 Distributor to a odb1 Distributor (B18C5-EH2)
Old Jan 7, 2004 | 04:30 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: Converting a odb2 Distributor to a odb1 Distributor (eh2)
thank u tom!! can i ask why u are at 99% ?
Old Jan 7, 2004 | 05:26 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">thank u tom!! can i ask why u are at 99% ?</TD></TR></TABLE>
I posted in a topic that was deleted, thus my post got deleted along with it. The automated system decucted 1% from my rating because I had a post deleted.
Old Jan 8, 2004 | 12:49 PM
SimbaDogg's Avatar
B18C5-EH2...what about if i'm putting a OBD I dizzy in a Non OBD car. the pins are totally different on the EF harness from the OBD I and OBD II dizzys
Old Jan 8, 2004 | 12:53 PM
GTlvr82's Avatar
Your pics didn't show for me...have a link or something. I need this info also...thanks alot...I though I was gonna shell out money for this...
But I have a obd2 dizzy with a obd1 harness...I didn't see any other plug....God I am confused now.
EDIT: Pics finally worked.
Modified by GTlvr82 at 5:09 PM 1/8/2004
Old Jan 8, 2004 | 01:18 PM
GTlvr82's Avatar
Default Re: Converting a odb2 Distributor to a odb1 Distributor (GTlvr82)
I just figured out why mine didn't look like your pics B18C5....because I have a obd2 wiring harness rigged up to work on a obd1 ecu/motor. I would assume I would need an ob1 harness to make the obd2 dizzy on my car work...sounds like lots of fun with wires.
Old Jan 8, 2004 | 01:28 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Converting a odb2 Distributor to a odb1 Distributor (SimbaDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SimbaDogg &raquo;</TD></TR><TR><TD CLASS="quote">B18C5-EH2...what about if i'm putting a OBD I dizzy in a Non OBD car. the pins are totally different on the EF harness from the OBD I and OBD II dizzys</TD></TR></TABLE>
You cannot do that. The OBD1 dizzy has a completely different pulse rate than the pre-OBD ECU/dizzy combo, so even if you wire it up correctly it will ALWAYS throw a code 4 and/or 9 for the crank and cylinder position sensors and your engine won't rev over 3500rpm and it'll run like ****.
What engine are you trying to out into what car? Maybe I can help you...
Old Jan 8, 2004 | 01:30 PM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTlvr82 &raquo;</TD></TR><TR><TD CLASS="quote">I just figured out why mine didn't look like your pics B18C5....because I have a obd2 wiring harness rigged up to work on a obd1 ecu/motor. I would assume I would need an ob1 harness to make the obd2 dizzy on my car work...sounds like lots of fun with wires.</TD></TR></TABLE>
Also for you too, what engine in what car are you running? What alternator and dizzy are you currently running?
GTlvr82's Avatar
My car revs as high as it wants....and I am throwing a code 9....
Old Jan 8, 2004 | 01:31 PM
GTlvr82's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
Also for you too, what engine in what car are you running? What alternator and dizzy are you currently running?</TD></TR></TABLE>
Alright....I have a B20B obd2 block, GSR ob1 head, alternator is from the B20B. The wiring harness seems to be a obd2 harness and I am running a skunk2 program (real one) for street/strip that is obd1.
EDIT: Car is a '94 hatch CX
Old Jan 8, 2004 | 01:35 PM
B18C5-EH2's Avatar
Former Moderator
Loved
EDIT: Car is a '94 hatch CX</TD></TR></TABLE>
Okay I see. I too run the OBD2 engine harness in my ITR hatchback with the Type R dizzy and alternator and I did not have to change any pins at all and I run a P28 rechipped as well.
Your code 9 means that you do need a new distributor though.
http://www.distributorking.com or click their banner ad. Awesome dizzys for awesome prices. Ask for Patrick.
Oh yeah ask for the OBD2 TD84 which fits all OBD2 GS-R, ITR, and B16A engines. It should be a one-plug direct fit with your OBD2 engine harness.
Old Jan 8, 2004 | 02:40 PM
SimbaDogg's Avatar
What engine are you trying to out into what car? Maybe I can help you...</TD></TR></TABLE>
well, i'm running and 1st gen b16 right now...but i'm getting a 97 ITR head, and w/ it is coming the OBD 2 dizzy. i have a OBD 0 to OBD I conversion harness and i was going to run a OBD I p30 ecu. thats why i was wondering if i could use the OBD 2 dizzy and run it as an OBD I. Otherwise i was gonna buy a OBD I dizzy, and sell this OBD 2. Make sense? i know the wiring can be done, cuz there are plenty of EFs out there running OBD I conversions w/ the stock EF harness.
Old Jan 9, 2004 | 04:15 AM
BLUE EH3's Avatar
Help we my pennies
THANK YOU!
Old Jan 10, 2004 | 10:17 PM
carbonblackeh's Avatar
What if I have an obd2 harness and a obd1 distributor, how do i make the plug fit&gt;? Will an obd1 ls distributor work? The motor is a b16a sir2
Old Jan 10, 2004 | 10:23 PM
rathead's Avatar
Default Re: (NEGATIVECAMBER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NEGATIVECAMBER &raquo;</TD></TR><TR><TD CLASS="quote">What if I have an obd2 harness and a obd1 distributor, how do i make the plug fit&gt;? Will an obd1 ls distributor work? The motor is a b16a sir2</TD></TR></TABLE>
you could use a obd1 distributor on a obd2 car. but you have to rewire it. you need the other end of the plug with wires on it and just match them up. i do believe the colors of the wires where different, i just took a 95 gsr wiring diagram, and a 98 civic diagram and sodder them together. it took me about 25 mins.
Old Jan 10, 2004 | 11:22 PM
B18C5-EH2's Avatar
Former Moderator
Loved
First of all the LS distributor won't work because the mounting "ears" are completely different than the VTEC distributors because the VTEC solenoid is in the way of one of the ears.
Secondly I guess you could always unpin those two wires pictured in my pics from the "extra" OBD1 plug and simply repin them into the two lower pins on the OBD2 plug for the distributor.
http://www.distributorking.com guys!
