cam seals, quick question
Old Jan 4, 2004 | 10:50 PM
NUTWEAVE's Avatar
Default cam seals, quick question
i am about to replace my stock gsr intake cam with an ITR intake cam. now since i have the valve cover off, i'm thinking about replacing little things all at once.
i read that the exhaust cam seals on older model integras are generally trash. now i have a 2001 gsr, should i replace either of my cam seals? i'm looking at some Golden Eagle cam seals, they are 30 bucks.
Old Jan 4, 2004 | 11:56 PM
NUTWEAVE's Avatar
Default Re: cam seals, quick question (NUTWEAVE)
anybody?
Old Jan 5, 2004 | 12:41 AM
Toda Built's Avatar
its always a good thing to replace... well the stock one is plastic and is known to leak after a while and by replacing it with a aftermarket one you are saving yourself the head ache later on.
Plus its inexpensive and easy to do
Old Jan 5, 2004 | 02:00 AM
aznsmtboy's Avatar
Default Re: cam seals, quick question (Toda Built)
aftermarket ____ is not always better then oem ____ though. Some things I would much rather have OEM.
Old Jan 5, 2004 | 04:27 AM
PM-Performance's Avatar
Default Re: cam seals, quick question (aznsmtboy)
The aftermarket cam seals are better for sure, ive seen plenty of those plastic ones leak after time . i replace em as soon as i take the valve cover off.
Old Jan 5, 2004 | 05:21 AM
WhatThaFrig's Avatar
Default Re: cam seals, quick question (itr206)
Save your self a headache down the road and spend $30 for an STR or equivalent cam seal. Well worth the money.
Old Jan 5, 2004 | 06:42 AM
Rod.'s Avatar
Go head and replace the cam seal. I replaced mines with a str one and does not leak anymore. Plus it looks good
TheWalrus
Jan 30, 2006 05:47 AM
DAintegraGSR
May 21, 2005 06:06 PM
StupidSlowRSX
Jun 2, 2004 10:30 AM
