Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Converting spring rates from kg/mm to lb/in
Old Jan 4, 2004 | 10:39 PM
DIRep972's Avatar
Smarter than you
Default Converting spring rates from kg/mm to lb/in
Sorry guys if this is a newbie question but I did a search and did not come up w/ anything. I know what spring rates I want for my car in lb/in but I am looking at some coilovers w/ 10kg/mm and i have no idea what that means.
Old Jan 4, 2004 | 10:56 PM
travis's Avatar
Default Re: Converting spring rates from kg/mm to lb/in (DIRep972)
1 inch ~ 25mm so 1mm ~ 0.039 inches
1 lb ~ 0.45 Kg so 1 Kg ~ 2.2 lbs
Old Jan 4, 2004 | 11:01 PM
DIRep972's Avatar
Smarter than you
Default Re: Converting spring rates from kg/mm to lb/in (travis)
ahhh thanks.. that means the 10kg/mm spring im looking at has a 564lb/in rating... exactly what i needed to know
Old Jan 4, 2004 | 11:07 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">ahhh thanks.. that means the 10kg/mm spring im looking at has a 564lb/in rating... exactly what i needed to know</TD></TR></TABLE>
Glad I could help.
FYI...
https://honda-tech.com/zerothread?id=46970
https://honda-tech.com/zerothread?id=258381
Old Jan 5, 2004 | 05:02 AM
.RJ's Avatar
.RJ
Multiply by 55.8...... i.e. 10kg/mm spring is 558 lbs/in.
pjr710
Suspension & Brakes
19
Apr 19, 2007 02:44 PM
The Jacko
Suspension & Brakes
Jan 31, 2006 01:44 PM
iLOVEmyEMone
Suspension & Brakes
Oct 19, 2005 11:07 AM
kndaqikEG
14
Dec 31, 2004 08:54 AM
E V I A N
Dec 16, 2004 09:08 AM
