cmi drag times
I ran my ek red hatch
ran
14.7 with radials93mph
14.6 with radials95mph
and a best of 14.5 with street tires and shitty 60ft(WEIRD)97mph
B16A2
ITR manifold,JDM DC 4-1 header,skunk2 stage1 cams,skunk2 ecu
my timing was retarted too and lots of boogign in vtec range
not bad first time at the track.
ran
B16A2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic2003 »</TD></TR><TR><TD CLASS="quote">the red svp crx was quick how much power u put down</TD></TR></TABLE>
500+HP@25psi
500+HP@25psi
Track was cold, helped the motor push a bit more power, but the tires just couldn't grip the ground.
13.5@107mph on street tires. Crappy 2.3 60' foots, going back with slicks and hopes to hit 12's.
My support group. Smaller then ussual, but everyone was was working. Hopefully should be getting another one of our hatches done by next cmi.
We have a freindly competition of all motor vs. turbo. (both full street cars) We'll see which one wins.
wat ur setup i ran 13.4 at 107 with a 2.3 60 ft with baby slicks spun first and 2nd i shift 1 gear at 7500 rpm to gain some tracktin so i wouldnt spin out wat ur setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2_9 »</TD></TR><TR><TD CLASS="quote">what kind of setup?</TD></TR></TABLE>
95 USDM GSR Swap
Right now I'm running LS compression (9:1) with a thicker headgasket
Custom turbo kit
Boosting 6-7 psi, open downpipe, downpipe ending is hella small....
Hopefully I will raise it up to 9 psi one day...but I'm fairly content with the 107 mph as it stands. I'm pretty sure I can break 12's with my mph. (I raced another car that hit 13.0@101 and another guy hit 12.6 @ 107 w/ 22 inch slicks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic2003 »</TD></TR><TR><TD CLASS="quote">wat ur setup i ran 13.4 at 107 with a 2.3 60 ft with baby slicks spun first and 2nd i shift 1 gear at 7500 rpm to gain some tracktin so i wouldnt spin out wat ur setup</TD></TR></TABLE>
Yeah it was slippery as hell. Just smashing the throttle down, it would loose traction with the ground as soon as the turbo spoiled, shifted to second, lost traction again. Hey what setup are you running in yoru car? What chasis was it? Any pics?
An all motor buddy doesn't think I can hit 11's on stock block. I'm shooting for it probably by summer time. Were both racing for the 12's...but I just have to slap on some slicks hopefully. Thanks for all the coments.
95 USDM GSR Swap
Custom turbo kit
i had a red civic si 92 with rota rnr in the back with baby slicks that didint grap for shiet full intereor i had a hard time hooking up
my setup jrsc 6psi b18c1 bone stock with 440 rc injectors
DOHC VTEC EF
10
Sep 14, 2004 12:10 PM
