Do Skunk2 coilovers work with Koni yellows?
Old Jan 4, 2004 | 07:29 PM
BeeSeriesEK4's Avatar
Default Do Skunk2 coilovers work with Koni yellows?
I have Skunk2 coilovers right now for my 96 EK. I plan on ordering some custom rated springs from Ground Control. I'm pretty sure the Skunk2 perch will fit the Eibach spring from GC. Does anyone know for sure?? And after i have the Eibach spring on the Skunk2 perch, will that set up fit onto the Koni Yellow?? thanks.
Old Jan 4, 2004 | 07:40 PM
Dveloped's Avatar
Default Re: Do Skunk2 coilovers work with Koni yellows? (BeeSeriesEK4)
yes they do k20eg on this board has them
Old Jan 4, 2004 | 07:42 PM
Ya@inlinePRO's Avatar
check with the ground control fellas
Old Jan 4, 2004 | 07:53 PM
Default Re: Do Skunk2 coilovers work with Koni yellows? (kwik2nec)
does K20EG have the Skunk2/Eibach combo on a set of Koni Yellows?? or "yes" as in the Eibach spring fits onto the Skunk2 perch?
Old Jan 4, 2004 | 08:10 PM
ej one's Avatar
to my knowledge the koni strut uses a slightly different adapter than the one that comes standard with the skunk2 coilovers
Old Jan 4, 2004 | 08:13 PM
Default Re: Do Skunk2 coilovers work with Koni yellows? (ehcoupe)
okayyyy...??? so ur saying no one with skunk2 coilovers is running Koni Yellows??
Old Jan 4, 2004 | 08:39 PM
JwM's Avatar
JwM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ehcoupe &raquo;</TD></TR><TR><TD CLASS="quote">to my knowledge the koni strut uses a slightly different adapter than the one that comes standard with the skunk2 coilovers</TD></TR></TABLE>
we ran into this problem with my cousins coilover perches, but we were able to make it work by turning the adapter from koni upside down so that the perches could seat correctly. It sounds more ghetto than it really was, and I don't know if it will relate to this situation, but since it might I thought i'd throw it out there...
Old Jan 4, 2004 | 09:33 PM
Dveloped's Avatar
he has skunk2 drag coils with koni yellows
Old Jan 4, 2004 | 09:43 PM
Default Re: Do Skunk2 coilovers work with Koni yellows? (electric_)
thanks guys for the info.
PINKFIFFTY
Suspension & Brakes
Mar 30, 2017 01:56 AM
PinoyCivic
May 24, 2006 12:10 PM
Brand
Suspension & Brakes
23
Apr 5, 2006 12:16 PM
singlecamcrx
Dec 6, 2004 08:47 PM
