JDM d15b VTEC HEAD
Old Jan 4, 2004 | 07:05 PM
Devine's Avatar
Default JDM d15b VTEC HEAD
Trying to get stiffer valvesprings and titanium retainers but no one seems to know what head the jdm d15b is related to, anyone have any ideas? I need solid info, no guesswork. TIA
Old Jan 4, 2004 | 07:09 PM
splitime's Avatar
Default Re: JDM d15b VTEC HEAD (Devine)
I believe it is a z6 head.
Z6 head
VX block
VX rods
some other piston (NON VX)
Old Jan 4, 2004 | 07:15 PM
Devine's Avatar
Default Re: JDM d15b VTEC HEAD (splitime)
I was under the impression that the rods were different, i read somewhere that the d15b has the same r/s ratio as a b16....
EDIT: Rods are 137mm (simliar in sized to the d16z6)Rods are stronger than vx, built like d16z6 rods.
R/S ratio : 1.62 (just like the b17a). Like stated above the head is most similar to the d16z6 92-95 si motor, i just want to be absolutely sure.
Old Jan 5, 2004 | 07:09 AM
splitime's Avatar
VX rods are the largest d-series rods... look for post about them from Mista-bone, he's done a few comparisons.
Old Jan 5, 2004 | 07:51 AM
BauleyCivic's Avatar
Risky Business
Default Re: JDM d15b VTEC HEAD (Kikomon)
VX rods are 137mm and have the lower wrist pin location...you can use VX rods in a 1.5L block and put 1.6L pistons on...meaning A6/Z6/A1 etc
D15 Rods are shorter and have a higher wrist pin location
Old Jan 5, 2004 | 08:26 AM
blackeg's Avatar
Default Re: JDM d15b VTEC HEAD (BauleyCivic)
z6 and d15b head castings are the same- d15b has a much better r/s ratio than the z6 as someone has already pointed out
Old Jan 5, 2004 | 08:31 AM
Slammd Sol's Avatar
Default Re: JDM d15b VTEC HEAD (blackeg)
So, can a jdm D15b take as much or more boost then a D16z6.. I know the d15b7's are weak..
Old Jan 5, 2004 | 10:22 AM
JimmyAtlantis's Avatar
Default Re: JDM d15b VTEC HEAD (Slammd Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammd Sol &raquo;</TD></TR><TR><TD CLASS="quote">...know the d15b7's are weak..</TD></TR></TABLE>
They aren't THAT weak.
1990hondaHF
May 7, 2006 02:05 PM
egizzle8
Nov 12, 2004 05:28 AM
4gzchatch
Nov 7, 2003 10:12 AM
91sleeper
Sep 9, 2003 09:13 PM
nerdsports
Jul 21, 2003 05:15 PM
