I need to know what size injectors i need to match my turbo.
i have a 96 honda accord 2 door f22b2 and a t3/t4 turbo i need to match the injectors and i dont know what size my stock injectors are how many cc's would you recomend for the t3/t4 (garret)
Is there anything else that i should know about for this project?
I have a set to sell. Used for 200 shipped. rc injectrs 440cc. email me jimmyt89@msn.com
I am assuming you have a drag or fmax kit. what is your desired hp ultimately? figure that out then get proper fuel management then get the injectors. in the meantime... http://www.rceng.com , they have a calculator that will assist you in the proper sizing. 440 is what is commonly tossed around for the f22b2 app (and is good for about about 350hp to the ground), but depending on your final desired result, it may vary. 550 isn't unheard of but at the same time, 335 may be all you need. either way, manage it well or you will have an idle from hell and an exhaust stench to match. jm2c
use the fuel injector calculations tools on one of the following links.
http://www.rceng.com/technical.htm
http://fuel.atrperformance.com/
and check out.
http://www.grapeaperacing.com/...s.cfm
and check out.
i would get RC 550cc, get a intank Walbro fuel pump, an adj. FPR, and since you're compatable with Hondata, get it too.
then run 10-12 psi, then when it's rebuild time, build and then max out the t3/t4 at 25-30 psi. i'll bet you'll break 400 easy. maybe close to 500, dont doubt the F22/F23 SOHC turboed.
central_driver
10
Feb 18, 2009 09:33 PM
