JDM R vtec solenoid same as USDM?? (almost)
Old Jan 4, 2004 | 03:22 PM
baonest1's Avatar
Default JDM R vtec solenoid same as USDM?? (almost)
well, my CEL 21 is on, the screen is clean, oil is up to level, and it even clicks when i apply 12V, but the valve doesn't move when i press on it.
a friend of mine has a JDM vtec solenoid, but it has no vtec pressure sensor on it (you need to tap it for the sensor).. i am curious if anything bad will happen if i drive the car. right now, i have no vtec at all (or is it better to drive it with the vtec disabled?). so will not having a vtec pressure switch hooked up throw any codes?? im trying to get my cage put in this week sometime, so i don't have much time to look for a USDM vtec solenoid. (unless someone has one cheap and read to ship)
thanks
Old Jan 4, 2004 | 03:24 PM
mstewar's Avatar
Default Re: JDM R vtec solenoid same as USDM?? (baonest)
on a USDM ecu? I expect it will throw a code.. On a JDM ecu, it wouldn't be a problem though..
I'd say just drive it without vtec to get the cage in, then worry about it later..
OT - Who's doing your cage?
Old Jan 4, 2004 | 03:28 PM
baonest1's Avatar
Default Re: JDM R vtec solenoid same as USDM?? (mstewar)
thanks for the quick response.
Primetime Racecars in g-boro is doing it (hopefully this week, i forgot to call friday ).
i havnt heard of anything going wrong by driving with vtec disabled. only thing is the CEL is on, but i havnt noticed limp mode or anything.
Old Jan 4, 2004 | 09:46 PM
Kicker773's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">on a USDM ecu? I expect it will throw a code.. On a JDM ecu, it wouldn't be a problem though..
OT - Who's doing your cage?</TD></TR></TABLE>
didnt' know that.. good info
Old Jan 4, 2004 | 10:22 PM
esponet's Avatar
if you use apex vafc, you will not need the oil preasure switch. its eliminated.
but yes on a u.s. ecu you will have chk eng. light, but will not hurt a thing.
duceducecord
Jan 29, 2007 03:14 PM
JeffBro
Oct 9, 2005 01:50 PM
SLOW4drINTEG
May 5, 2003 10:47 PM
