gsr cluster in a 90 si!!!! VSS wire up!! HELP!!!!!!!!!!!!!!!!!
Old Jan 4, 2004 | 12:29 PM
All_Motor EF9's Avatar
Default gsr cluster in a 90 si!!!! VSS wire up!! HELP!!!!!!!!!!!!!!!!!
SUP GUYS! NEED HELP. A GSR CLUSTER IN A 90 SI? I HAVE EVERYTHING WORKING. ONLY PROBLEM SPEEDO IS NOT WORKING CUZ OF THE VSS. NEED HELP WIRERING VSS WITH THE CLUSTER.
HEARD SOMETHING ABOUT RUNNING THE SIGNAL WIRE FROM THE VSS TO THE CLUSTER. THEN SPLICING A WIRE AND RUNNNING IT TO THE ECU.
NEED HELP TO MAKE SURE THIS IS CORRECT.
IF ANYONE HAS DONE IT AND IS WORKING HOOK A BROTHER UP!!!!!!
THANKS GUYS PEACE.......
Old Jan 4, 2004 | 01:00 PM
Fobtions's Avatar
Default Re: gsr cluster in a 90 si!!!! VSS wire up!! HELP!!!!!!!!!!!!!!!!! (All_Motor EF9)
on the sensor itself it needs a ground, power with key, and for the signal i ususally run a wire that goes from the ecu to the cluster with the vss signal tapped into it.
Old Jan 4, 2004 | 03:27 PM
Kilohead36's Avatar
Default Re: gsr cluster in a 90 si!!!! VSS wire up!! HELP!!!!!!!!!!!!!!!!! (Fobtions)
If you search this forum a guy just swapped in a 99 si cluster into his crx..he has wiring details..Check with him..
Old Jan 4, 2004 | 05:29 PM
Default Re: gsr cluster in a 90 si!!!! VSS wire up!! HELP!!!!!!!!!!!!!!!!! (Kilohead36)
i saw the post about the 99 si cluster in a crx. I tried it the way he did it and its not working. maybe im doing it wrong that why i wanted to asks other people if they know and could explain it to me
afterdark
13
Apr 30, 2009 10:12 AM
gkssn
Feb 22, 2009 07:08 PM
USDMSiR
15
Aug 31, 2006 02:07 PM
I LOVE MY EF9
Jan 18, 2004 10:01 PM
