which injector is #1, the dist. side or the timing belt side?
Old Jan 4, 2004 | 11:52 AM
xhatchracerx's Avatar
Default which injector is #1, the dist. side or the timing belt side?
like the topic says i dont know which injector is considered #1. does it go:
(dist.) #1 #2 #3 #4 (timing belt) or (dist) #4 #3 #2 #1 (timing belt)
the reason im asking is because i was running OBD1 injectors but now im running ODB2 injectors, therefore i had to change the injector harness back to OBD2 plugs.
I have a 96-98 civic manual and a 94+ integra manual that both says;
(dist) #4 #3 #2 #1 (timing belt) ,but i believe that when the OBD1 injectors were wired it was wired the other way (dist.) #1 #2 #3 #4 (timing belt)
does it matter which way they go?
Old Jan 4, 2004 | 12:08 PM
flat-blk-HB's Avatar
Default Re: which injector is #1, the dist. side or the timing belt side? (xhatchracerx)
(dizzy)4 3 2 1(t-belt)
eg6T
Aug 14, 2005 02:35 AM
OzWolfbane
Jan 7, 2005 05:14 PM
