is it bad to use a higher amp rating fuse for the "ecu" fuse under the hood?
Old Jan 4, 2004 | 08:03 AM
Project_ED8's Avatar
Default is it bad to use a higher amp rating fuse for the "ecu" fuse under the hood?
i just picked up a 88 crx hf w\b16 less than a week ago and i'm just doing an over-haul of everything and i noticed while i was looking at all the fuses that are in the fuse box under the hood the ecu fuse had one rated at 30amps but on the cover it says it should be 15A and it says "only use the amperage for the fuse its rated for" or something like that. well would it matter if there is a 30a fuse instead of a 15? did he use a higher rated fuse because its a different ecu i'm running or simply cause he didn't have any others available! this isn't a big problem...just something i'd like to get clarified so i know. ok thanks
Old Jan 4, 2004 | 08:18 AM
Home Skillet's Avatar
Default Re: is it bad to use a higher amp rating fuse for the "ecu" fuse under the hood? (Project_ED8)
General rule of thumb. Never use a higher fuse rating than the manufacturer requires.
Old Jan 4, 2004 | 10:53 AM
virginia_dude's Avatar
never ever put a bigger fuse, if it pops find out why, you will end up burning up something or melting down your harness with an excessivey large use. If everything is right it will never pop the correct one.
Old Jan 4, 2004 | 11:33 AM
chet's Avatar
Default Re: is it bad to use a higher amp rating fuse for the "ecu" fuse under the hood? (virginia_dude)
chances are the previous owner replaced the fuse with a different one because it was all he had. honda has specs from the factory which are designed to work...and changing them is only going to do damage.
Old Jan 5, 2004 | 04:59 AM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virginia_dude &raquo;</TD></TR><TR><TD CLASS="quote"> if it pops find out why.</TD></TR></TABLE>
The fuses from the factory are already overkill or they would blow all the time after little spikes. If you're going to replace a fuse with something larger than spec, you may as well just bridge it with wire.
tshuajzoo559
May 30, 2008 10:25 AM
pr0j3xt01v1c
Honda Civic (2001 - 2005)
Aug 10, 2007 06:34 AM
E46Kid
Sep 16, 2005 10:18 AM
jimbeamsEK
Jan 28, 2005 10:25 AM
Andrew 825SM
Apr 5, 2003 04:50 PM
