Is it gonna work????
Old Jan 4, 2004 | 01:47 AM
yaris's Avatar
Default Is it gonna work????
I bought Skunk2 intake manifold,skunk2 stage2 camshafts with valve springs and retainers, skunk2 camgears,ECU P28 with Skunk2 program(48oo-9000rpm),DC header 4-1.
When i put everything in, is it gonna work properly or should I increase compression
P.S. car is civic SI
Old Jan 4, 2004 | 02:01 AM
rodrez.'s Avatar
Default Re: Is it gonna work???? (yaris)
It'll work fine. But personally, I would up the compression. Those cams need more than the stock B16 comp to see the full potential.
Old Jan 4, 2004 | 02:13 AM
yaris's Avatar
Default Re: Is it gonna work???? (rodrez)
Do you recomend anything for incresasing the compression?
Old Jan 4, 2004 | 02:15 AM
The Internet Tough Guy's Avatar
ummm how bout some pistons...
Old Jan 4, 2004 | 02:17 AM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yaris &raquo;</TD></TR><TR><TD CLASS="quote">Do you recomend anything for incresasing the compression?</TD></TR></TABLE>
There's a few ways you could do it: new pistons, thinner headgasket, or milling the head. I prefer piston replacement, but the thinner headgasket would be really simple, and quick, it'll give you a tad bit more compression to take advantage of.
Old Jan 4, 2004 | 02:26 AM
yaris's Avatar
Which pistons do you recomend, is it CTR pistons o.k.?
ninja95gsr
Sep 14, 2010 12:54 AM
tegra2G
11
Oct 26, 2008 04:37 AM
Drew17th
Oct 30, 2006 05:35 PM
96redgsr
25
Aug 26, 2003 10:45 AM
