Sparkplug choices
Old Jan 3, 2004 | 10:46 PM
ITR_1211's Avatar
Default Sparkplug choices
Just wondering what brand sparkplug everyone here prefers
Old Jan 4, 2004 | 12:36 AM
iam7head's Avatar
Default Re: Sparkplug choices (Darryl Mussashi)
dont waste your money,
copper plugs works just fine for me, boosted or not.
NGK copper plugs serve me well, not to mention they are cheap.
Old Jan 4, 2004 | 07:50 AM
ITR_1211's Avatar
bump
Old Jan 4, 2004 | 11:02 AM
rudebwoy's Avatar
whats the part number for a colder ngk spark plug?
Old Jan 4, 2004 | 02:00 PM
Cynical 1's Avatar
Default Re: Sparkplug choices (Darryl Musashi)
Hondas love OEM plugs (NGK Copper), but if I was to switch, I'd run Denso Iridium. My Jetta loves them.
Old Jan 4, 2004 | 03:00 PM
Turbo12acer's Avatar
NGK V-POWER PLUGS ALL THE WAY!!!!
Old Jan 4, 2004 | 03:28 PM
katzenjammer84's Avatar
I've heard good things about the NGK V-Power plugs. I might use them next time around, although my current Bosch plugs work fine too.
Old Jan 4, 2004 | 04:23 PM
Kendall's Avatar
The V-Power's are good, but I've had better results with the Denso Iridium's. I'm thinking of trying the Spoon plugs next.
Old Jan 4, 2004 | 06:58 PM
slow_dx's Avatar
Default Re: (rudebwoy)
For my b16a2, NGK BKR7E is one heat range cooler. BKR8E is two heat ranges cooler.
You're on your own for the sohc.
Got mine at http://www.clubplug.net
Old Jan 5, 2004 | 10:15 AM
rudebwoy's Avatar
Default Re: (slow_dx)
I went to the link and I saw what I looking for, but they listed them by quantity of one, does this mean its 1 plug, or one set?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_dx &raquo;</TD></TR><TR><TD CLASS="quote">For my b16a2, NGK BKR7E is one heat range cooler. BKR8E is two heat ranges cooler.
Got mine at http://www.clubplug.net</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_dx &raquo;</TD></TR><TR><TD CLASS="quote">For my b16a2, NGK BKR7E is one heat range cooler. BKR8E is two heat ranges cooler.
Old Jan 5, 2004 | 12:20 PM
slow_dx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy &raquo;</TD></TR><TR><TD CLASS="quote">I went to the link and I saw what I looking for, but they listed them by quantity of one, does this mean its 1 plug, or one set?</TD></TR></TABLE>
I'm pretty sure it's for a box of 10. It explained it better at the checkout, IIRC.
Old Jan 5, 2004 | 12:35 PM
rudebwoy's Avatar
do I still need to use colder plugs with 9.1 compression, boosted? and which is better iridium or regular for turbo?
Old Jan 5, 2004 | 01:58 PM
slow_dx's Avatar
I don't know about a turbo setup. My own setup is N/A, but I have been getting some pinging in stop and go traffic, which is what prompted me to install the plugs. I figured it was cheap insurance.
How much boost are you running?
Consider installing a set and checking them periodically. If the plugs are fouling on you, you can either run it harder or switch back to stock.
Old Jan 5, 2004 | 08:25 PM
CRXLST's Avatar
I just replaced my plugs with copper... It runs great and seems to get better spark.. I had a little skip but its all gone now...
Old Jan 6, 2004 | 06:34 AM
dip-set's Avatar
Default Re: Sparkplug choices (CRXLST)
what ngk v power plug is one heat range cooler than the stock plug...my car pings occasionally also when hot out or ive been running the car hard...thanks..
Old Jan 6, 2004 | 09:43 AM
Home Skillet's Avatar
NGK V power
Old Jan 6, 2004 | 09:49 AM
ejprimo's Avatar
Default Re: Sparkplug choices (Home Skillet)
denso K20PR-L11 (3144) spark plugs.
Old Jan 6, 2004 | 12:56 PM
slow_dx's Avatar
Default Re: Sparkplug choices (teg-your-it)
Does v-power mean that the plug has a 'v' shaped groove in the electrode?
the BKR7Es that I installed had that.
dman81
Feb 2, 2014 11:10 AM
dpdawson
Honda Civic (2001 - 2005)
24
Dec 22, 2008 08:29 PM
Markov
Oct 7, 2005 10:33 AM
wreckedmyteg
Jan 25, 2005 02:03 PM
Ef Whore
10
Nov 27, 2002 05:37 PM
