gsr or ls tranny
Old Jan 3, 2004 | 08:24 PM
boostng r's Avatar
a
Default gsr or ls tranny
how do i know if i got a gsr or ls tranny i got a b16a and a p30 b16 del sol what is the mph on 1 thru 5 gear on gsr and 1 thru 5 on ls thanks
Modified by b16coupe4 at 6:59 AM 1/4/2004
Old Jan 3, 2004 | 08:35 PM
cstay's Avatar
Default Re: gsr or ls tranny (b16coupe4)
re read what u just posted then re write what u really wana say.
Old Jan 3, 2004 | 08:40 PM
chad's Avatar
Moderator
Default Re: gsr or ls tranny (cstay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cstay &raquo;</TD></TR><TR><TD CLASS="quote">re read what u just posted then re write what u really wana say. </TD></TR></TABLE>
honestly....i agree.....ENGLISH M-Fer
Old Jan 3, 2004 | 10:00 PM
boostng r's Avatar
a
Default Re: gsr or ls tranny (chad)
ok thanks
Old Jan 3, 2004 | 10:02 PM
Ricey McRicerton's Avatar
The LS tranny is more similar to an EX transmission on a D series ratio wise. The GSR is a bit shorter.
Old Jan 3, 2004 | 10:54 PM
RC_SKUBY's Avatar
the gsr has shorter gear ratios, the ls are longer. and if im right the ls tranny tops out at around 145 and the gsr at aorund 135(give or take a little)
Old Jan 3, 2004 | 11:04 PM
Jer's Avatar
Jer
Default Re: gsr or ls tranny (skuby_do)
for a b16, you dont want either. the gears are too long and spaced for the torqueless wonder. you need a b16 tranny or type r. if you have to go with one of the two though, you need a gsr tranny.
a ls tranny on a b16 will be about as quick as a d16z6.
Old Jan 4, 2004 | 09:00 AM
boostng r's Avatar
a
Default Re: gsr or ls tranny (GERM)
ok how do i find out what i got in my car i dont even got one sticker on the tranny
my first gear tops out at like 38 or 39
Old Jan 4, 2004 | 09:35 AM
RTE117's Avatar
[QUOTE=GERM]for a b16, you dont want either. the gears are too long and spaced for the torqueless wonder. you need a b16 tranny or type rQUOTE]
the B16 and GSR both use 4.4 FD's with the exeption of a longer 3rd gear? and the LS is something around a 4.2 FD..
Old Jan 4, 2004 | 09:49 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe4 &raquo;</TD></TR><TR><TD CLASS="quote">ok how do i find out what i got in my car i dont even got one sticker on the tranny
my first gear tops out at like 38 or 39 </TD></TR></TABLE>
You'll need to give us the tire size, and preferably some speeds and RPMs in other gears . . .
Old Jan 4, 2004 | 09:51 AM
Jer's Avatar
Jer
Default Re: gsr or ls tranny (IDriveAHonda)
[/QUOTE]
the B16 and GSR both use 4.4 FD's with the exeption of a longer 3rd gear? and the LS is something around a 4.2 FD.. [/QUOTE]
go check again, the b16 has a shorter 2nd,3rd, 4th, and 5th compared to a gsr tranny. yes they have the same final drive of 4.40 but the final drive determines the top speed for each gear. the gear ratio determines how far the rpm's drop between shifts.
go put a gsr tranny on a b16 and then you tell me if they are the same with the exception of a longer 3rd
oh and for the guy who posted this thread, what is your rpm when cruising in 5th at 80mph. ill be able to tell you from that.
Old Jan 4, 2004 | 10:02 AM
RTE117's Avatar
well thanks for clearing that up, i never knew that
Old Jan 4, 2004 | 10:07 AM
zigs's Avatar
You will have to do a top speed in another gear like 3rd cause ls and gsr trannies have the same first gear.
Old Jan 4, 2004 | 11:11 AM
boostng r's Avatar
a
ok i will check my rpm at 80 mph um 1 gear is 38 and then 2nd gear is 68 i will check the rest
Old Jan 4, 2004 | 11:16 AM
SleepnCiViC's Avatar
not sure but sound like a LS tranny w/ 68mph 2nd gear redline
Old Jan 4, 2004 | 11:42 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe4 &raquo;</TD></TR><TR><TD CLASS="quote">ok i will check my rpm at 80 mph um 1 gear is 38 and then 2nd gear is 68 i will check the rest</TD></TR></TABLE>
Tire size???
Sounds like you probably have an LS.
Old Jan 4, 2004 | 11:56 AM
Jer's Avatar
Jer
Default Re: gsr or ls tranny (Targa250R)
id think its a gsr. he has the same red line as me and i can take mine to about the same speeds through first and second.
Old Jan 4, 2004 | 12:03 PM
B18C2_sedan's Avatar
gsr is a better drag tranny
Old Jan 4, 2004 | 12:11 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GERM &raquo;</TD></TR><TR><TD CLASS="quote">id think its a gsr. he has the same red line as me and i can take mine to about the same speeds through first and second.</TD></TR></TABLE>
But do you have the same tire size as he does?
Old Jan 4, 2004 | 12:35 PM
BigBlockCRX's Avatar
New User
205 55 15 he also got a pair of 195 60 14
oh and 5th gear at 80 mph my rpm is 3100 this is b16 coupe4 thanks guys
Old Jan 4, 2004 | 12:45 PM
Targa250R's Avatar
be professional
Default Re: gsr or ls tranny (BigBlockCRX)
You have an LS tranny.
With the GSR tranny, your revs would be around 3900 or so in 5th at 80mph.
Old Jan 4, 2004 | 01:19 PM
Jer's Avatar
Jer
wow only 3100 mine is at 4k on the dot at 80 in a gsr hatch with gsr tranny. thats with 205-50 15's
you must have a ls tranny.
by the way, how you been josh? hope i can make it out a lot next season
Old Jan 4, 2004 | 03:13 PM
boostng r's Avatar
a
so i have a ls my third gear is at 89 mph this sucks if i have a ls
Old Jan 4, 2004 | 03:25 PM
BauleyCivic's Avatar
Risky Business
GSR tranny is shorter and has MUCH better 3rd-5th gears...
however...with a GSR you will sit at 3,000 RPM at 60mph
Old Jan 5, 2004 | 08:11 AM
boostng r's Avatar
a
Default Re: gsr or ls tranny (BauleyCivic)
yeah i got this tranny from a friend that owns a shop but a **** whole shop but anyways he gave me no paper work or anything and the tranny had no stickers or nothing i guess this tranny is no good for allmotor i paid 400 like a stupid ***
