NSX Motor Swap
Why would you want to do that? Do you have an NSX with a blown motor or something?
NSX engines don't croak - not if they're properly maintained, anyway. We have a bunch of owners with 150K+ miles on theirs, and a couple of them have 200K+ miles. No croaking.
[Modified by nsxtcjr, 10:47 PM 9/26/2001]
Thats good to hear.
But still, say if I bought one with 150K on it, and I wanted to redline it daily, and take to to highperformance driving schools, and autocrosses. I would need to know the 'what ifs'. A rebuilt nsx engine is around $7,000 right?
If you can't afford it, then don't buy it.
I take it they wont continue making this nsx engine when the new nsx comes out. What if I throw a rod through the block. Can't rebuild it...
[Modified by jond, 11:03 AM 9/27/2001]
Why would you put a old nsx engine in it. You could just buy a supercharger and make more power....
[Modified by jond, 11:30 AM 9/27/2001]
If you can't afford it, then don't buy it. You should save more money and buy low mileage one in good condition.
While the NSX is very reliable, things do occasionally go wrong. And you need to be prepared to spend money to fix them - which means being able to afford $2K if the clutch goes out, or $2-5K if the air conditioning goes. On a car with 150K miles, the chances of problems happening go up a lot.
What you spend on your car should be money you have available above and beyond more important priorities, like money for your housing and food and investing for the future and having something on hand in case of an emergency. If this doesn't leave you $32-35K to spend on the car, plus a few grand left over in case something happens, then don't buy an NSX. Not a good idea.
I appoligize for asking a technical question in the S2000/NSX board. I guess I should keep to the 'what wax to use' questions here.
And ak... Do you even have a car you highschool ****.
[Modified by jond, 7:15 PM 9/27/2001]
I dream about stuffing in an inferior economy engine into otherwise great sports car
Why would you spend 7-10K on a new NSX engine on a 10 year old 23,000 car?
Plus a supercharged accord V6 would make more hp...
couldnt work because the tranny from the nsx wouldnt bolt up to the accord motor.
I guess the NSX motor has a bolt pattern thats unique to all honda engines?
[Modified by jond, 12:12 AM 10/2/2001]
Jon,
this is only getting a slightly better response than STEVO C's question about swapping an NSX mill into the rear of his ITR. I guess the gist is the same - "I want to defile my sports car, what do you guys think?" The NSX motor is a gem. And it's a Honda, which means it will last. Just leave it be.
Take for example this one:
Its only $22,000, but it has 130,000 miles on it. You would probably have another 70,000 or so left on it, but what then? It would then be worth probably $12,000 and a new nsx engine cost $10,000??? Sounds like someones going to get stuck with the hot potato with a old nsx. Unless of course, theres a way to swap in a equally powerfull engine, or cheaply rebuild the current one. Whatever...
http://www.autotrader.com/findacar/v...&ac_afflt=none
[Modified by jond, 6:48 PM 10/8/2001]
