HELP! HELP! LSD axle Question?
Old Jan 3, 2004 | 06:52 PM
dwchkypmp20's Avatar
Default HELP! HELP! LSD axle Question?
can i use no LSD axles with my LSD transmission? Currently a OBD-0 b16 with lsd.....have non lsd axles....in other word can i mix non lsd axles with lsd half shafts? HELP!
Old Jan 3, 2004 | 07:13 PM
virginia_dude's Avatar
Default Re: HELP! HELP! LSD axle Question? (dwchkypmp20)
there are no LSD and NO lsd axels to my knowledge. THere are ABS and non-abs axels however.
Old Jan 3, 2004 | 09:45 PM
Default Re: HELP! HELP! LSD axle Question? (virginia_dude)
i was told that my non lsd axles would not work with my lsd motor......becuase the half shafts would not match.........and i know for a fact that there are lsd motors.............type r
Old Jan 3, 2004 | 09:59 PM
guttedEF's Avatar
There are no LSD motors. There are LSD transmissions, and that is fairly common. That should have nothing to do with what axle will or will not work for it. As long as the diameter and splines match up, it will work, period. There is no LSD or non-LSD axles, only ABS or non-ABS.
Did you recently get a swap and go from a D-series engine to a B-series engine? If so, that could be it, because the axles are different for each one.
What is your swap and tranny and what kind if chassis? Someone here can tell you what axles will work.
Old Jan 3, 2004 | 10:04 PM
Caleb V's Avatar
Default Re: HELP! HELP! LSD axle Question? (guttedEF)
Whomever said that probably was refering to the fact that the Y1 intermediate shafts are longer. I would just get a set of complete 90-93 Integra LS axles so that you don't have to build custom axles (86-89 Integra shafts/outer joints with 90-93 Inner cups) There used to be a great writeup on what you needed to do with whatever intermediate shaft you had on Hasport but now they sell their custom axles so I haven't been able to find it. Buy some from Hasport, Raxles can make you a custom axle but I think you have to supply both sets of cores to get them to do it.
Old Jan 3, 2004 | 11:38 PM
Default Re: HELP! HELP! LSD axle Question? (Caleb V)
MY CAR IS CURRENTLY AT AUTOELINK IN TEMPLE CITY...THEY ARE FINISHING MY LSD B16 INTO A 91 CRX....AND I WAS TOLD THAT I WAS GIVEN THE WRONG AXLES TO MATCH UP TO MY TRANNY.......SOMETHING A LONG THE LINES THAT MY HALF SHAFTS ARE LSD AND MY AXLES WONT MATCH UP
PS THEY ARE BRAND NEW 90 INTEGRA AXLES
Old Jan 4, 2004 | 01:36 AM
Caleb V's Avatar
You were told wrong, whomever told you that is an idiot and is probably trying to make a little extra money by selling you some more parts if you supplied the axles yourself. There is no such thing as an LSD axle, they were probably on LSD themselves.
PS-mind the caps we heard you the first time.
dragaholic
Jan 20, 2006 05:48 PM
WickedMotorsports
Jan 8, 2006 12:01 PM
tallblondkid
32
Jul 11, 2004 08:36 AM
d mafia
Jan 18, 2002 09:52 PM
