99 Accord Short Shifter How does it install?
Ii dindn't came with the instructions?
You might have some frinds that have done this in your town. try to check with them!
When you get it installed tell me how it works please, i want to get that too.
see ya
see ya
The collar fits around the shifter arm +
The hole goes on the OE shaft holding the current linkage.
The linkage goes on the bolt and fits to the body of the adapter.
The peak of the adapter should face up.
this is just a knock off of the B&M shifter kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97accord »</TD></TR><TR><TD CLASS="quote">here you go this is a pic of what it should look like installed..this is how i figured mine it..i was a bit confused too!
The bolt goes into your linkage and the front part goes onto your shifter.....pretty easy (hardest part is removing the plastic interior and getting to the shifter and linkage)
hoychristian
Transmission & Drivetrain
10
Feb 9, 2016 03:19 AM
