Pics of DA cluster in a EG?
Cluster, i doubt because of the SQUARISH shape of the cluster...
Seats have the wierd ELECTRIC/AUTO seatbelt thingy on the sides so it would look wierd, not sure of the bolt patern though...
Anything will fit into any car. Its just the amount of time and money you want to put into it. IMO its not worth it. I wouldnt change the dash out for anything else excpet for a black one. The integra dashes i dont like because i dont think it flows with the car. Its too zoomy for the car. Im pretty sure the DA seats would fit with a little bit of modding. Probably if you swapped the brackets, etc.
Guest
Posts: n/a
Completely forgot about the seatbelt setup but it shouldn't be that hard to do those. I've got an older recaro that is kinda the same design as the DA's seats. Maybe I'll just pass on the motor and just get off my *** and finally install my turbo.
Well, the DA cluster also has a cable drive speedo. You'd have to figure out how to route the cable in addition to all the wiring. Better off using a DC2 cluster.
Seats aren't supportive enough to be worth your time. However, there is absolutely nothing acutally on the seat that has anything to do with the seat belts...
i think DA seats are plenty supportive and my friend had 92 gsr seats in his 93 si. I believe he swapped rails and just cut the power seat belt thing off and left the female end of the seatbelt connector.
SiBlueEG6
Sep 4, 2009 07:25 AM
jadugartir
Oct 9, 2006 07:42 PM
